White smoke! help diagnose prob..
Old Nov 24, 2002 | 08:06 PM
R-1303's Avatar
Default White smoke! help diagnose prob..
My friends GSR is pushing out white smoke from the exhaust when revving 6-8000Rpm...what could be the cause???
Mods: intank, header, cat back exhaust..
the dealership is giving him the run around saying these mods are the cause but i don't see how at all.
Old Nov 24, 2002 | 08:53 PM
poo flinger
Guest
Posts: n/a
Default Re: White smoke! help diagnose prob.. (R-1303)
What year GSR? Sounds like a fuel prob to me.
Old Nov 24, 2002 | 10:14 PM
jay99EK's Avatar
is it PURE white smoke or is it white smoke with a blue tint??
white smoke could be coolant or water leaking into your combustion chamber~ that could be from a bad head gasket or a cracked block or cylinder head~ get an engine diagnosis and check to see if that's the prob~
if its white smoke with a blue tint then that's engine oil being burned and that's from oil leaking into your combustion chamber, or worn piston rings, cylinders or valves or a bad head gasket.
get it checked out
Old Nov 25, 2002 | 04:12 PM
R-1303's Avatar
Default Re: White smoke! help diagnose prob.. (jay99EK)
get it checked out
Thanks!..i thought it was coolant no tint of blue to the smoke..but oil consumption has dropped he says..would a bad head gasket cause it to smoke only around 6000-8000 Rpm??
Old Nov 25, 2002 | 04:28 PM
Jay J's Avatar
Prince of Zamunda
Did you check that stuff
Old Nov 26, 2002 | 01:41 AM
jay99EK's Avatar
yea its possible i would assume~ if the leak is small enough.. but even the smallest leak can soon turn into a big one if not addressed right away~ i suggest not driving it as much.. only drive it if necessary.. and get it fixed as soon as possible or else you risk damaging your engine~
2kdrift
15
Feb 26, 2017 05:58 AM
lilpaintballer02
22
Mar 5, 2010 08:13 AM
boostedjdmdc2
Oct 22, 2006 08:16 PM
CRX_Control
Nov 10, 2004 09:29 PM
R-1303
Nov 26, 2002 06:38 AM
