Fitting Miata wheels on a Civic..
Old Nov 25, 2002 | 03:31 PM
flat-blk-HB's Avatar
Default Fitting Miata wheels on a Civic..
Ok I am aware that the inside has to be grinded out to fit and I am in the process of doing just that. But do I need to grind out the entire thing all the way to the front, or just the inside. I know somebody has done this...BTW these are '91 miata wheels. 14x5.5"...Thanks.
Old Nov 25, 2002 | 03:39 PM
Spade's Avatar
Default Re: Fitting Miata wheels on a Civic.. (Stealth_Bomber)
Why would you grind and weaken something that pretty much if it fails has your life on the line?
Hello wheel spacers.
Old Nov 25, 2002 | 04:04 PM
Default Re: Fitting Miata wheels on a Civic.. (Spade)
Well I dont have the extra cash for the wheel spacers, and I am not weaking the rims that much or hardly at all.
Anyways does anyone know anything to help me??
Old Nov 25, 2002 | 04:08 PM
WiZeBaNaNa's Avatar
New User
i suggest you go find the price on some wheel spacers (non-H&Rs)... they're relatively cheap...
Old Nov 25, 2002 | 04:18 PM
Default Re: Fitting Miata wheels on a Civic.. (WiZeBaNaNa)
Well I already started grinding and filing the centers out. So I guess I will figure out what needs to be done on my own.
Old Nov 25, 2002 | 05:00 PM
owen_the_soyboy's Avatar
a machine shop is the right spot to do it right, bore out the center for the larger "register" of the Honda hub.
but yes you can do it yourself with a few home tools / grinding bits.
you need enough clearance for the hub register, whatever its diameter is an dwhatever distance it protrudes past the wheels mounting surface... on the rotor hat face actually. Cant be that deep, what maybe a quarter inch?
well nice choice on wheels and good luck
Old Nov 25, 2002 | 05:53 PM
Default Re: Fitting Miata wheels on a Civic.. (owen_the_soyboy)
Thanks Owen that is basically what I wanted to hear. I took them to a machine shop that is in front of the shop where I work and they said that were not sure if that could do that. ..So that meant I was goning to be doing it my self.
H_s2k_H
Apr 10, 2012 10:56 AM
gosu08
Oct 22, 2010 09:17 AM
siblues
May 5, 2008 09:39 AM
seannabend
Oct 12, 2004 07:51 AM
