Making tool, are B crank pully same as H
Old Nov 22, 2002 | 07:58 AM
legendboy's Avatar
Default Making tool, are B crank pully same as H
I just need to know if the bolt and inner bolt for holding the pully is the same. Thanks.
Old Nov 22, 2002 | 09:28 AM
Kataku2K3's Avatar
Default Re: Making tool, are B crank pully same as H (legendboy)
Bolt and Inner bolt??? If you are refering to the 19mm bolt that holds the crank pulley on, yup they are all the same...
Old Nov 22, 2002 | 10:42 AM
legendboy's Avatar
Default Re: Making tool, are B crank pully same as H (JDMspecEG6)
If you look at a crank pulley you'll notice that the area around the hole for the 19mm bolt is actually an 8 point socket size. This is designed so that you can use a special snap on tool to hold the crank pulley while in the center of the tool head, there is a hole where you can then slide a 19mm socket on the bolt and wrench it off.
Layne Barber
Apr 17, 2015 12:38 PM
barrera
Oct 11, 2010 07:17 AM
Midori Green
Jun 3, 2008 07:00 PM
puffsef
Oct 19, 2005 09:50 AM
