oxygen sensor faulty will it affect the VTEC?
bcos i juz done engine swap on my car. swapping zc to a jap spec b16a. and my mechanic juz told me that my O2 oxygen have to change but did not told me that the VTEC is not working.
VTEC will work. I drove around for over a month with the O2s disconnected, VTEC worked fine.
Hell, I wasn't even getting a CEL
and even when I DID get a CEL VTEC still worked fine.
[Modified by raene, 2:25 AM 11/24/2002]
and even when I DID get a CEL VTEC still worked fine.[Modified by raene, 2:25 AM 11/24/2002]
your o2 sensor check engine light shouldnt come on right away. it should come on after driving in 3 rd gear and deaccelerating (i think that was the gear). if the light comes on right away, maybe you should look to see if something else is wrong. what code are you getting and what ecu are you using?
3rd gear check engine light is for oxygen sensor? damm i gotta replace mine thanx for the tip lol now..which O2 sensor fits for the jdm b16
well what motor and generation motor are you running? check the ecu to see what codes its throwing. thats the only way youre gunna find out.
yea im runnin no o2 sensor right now and VTEC works perfect, just running rich as hell and sometimes the car is VERY laggy under 3k rpm.
ep3_frk_out
11
Dec 1, 2011 01:17 AM
