weird noise when I turn Left??
Old Nov 22, 2002 | 11:57 PM
RegRedTeg's Avatar
Default weird noise when I turn Left??
its kind of a winding noise like something is twisting up, but its only when I turn left. also I dont know if its my sub box i put in buy my drivers side is really low like a 2in drop and on the passenger side its a 1.5 drop which it should be.
Old Nov 23, 2002 | 12:05 AM
bokguay's Avatar
Default Re: weird noise when I turn Left?? (RegRedTeg)
explain the noise and where do u hear it comeing from..what does it sound like?
Old Nov 23, 2002 | 12:08 AM
RegRedTeg's Avatar
Default Re: weird noise when I turn Left?? (bokguay)
I can hear it coming from the drivers side, and the noise is like a scratching twisting sound, with a high pitch.
Old Nov 23, 2002 | 12:12 AM
bokguay's Avatar
did u juss drop ur car..cause if u did its prolly that...if not it might be the dust cover behind the rotor scrating the rotor when turning left...cause that happended to me before and it sounded like metal rubbing on metal
Old Nov 23, 2002 | 12:15 AM
RegRedTeg's Avatar
yeah it kinda sounds like metal rubbin against it, any idea why the drivers side is lower right now, when I first installed it and month after its fine but now drivers side is pretty low like right on the tire, im thinkin it might be the box i have in but I dont think its that heavy
Old Nov 23, 2002 | 12:18 AM
bokguay's Avatar
naw...the drivers side is lower because u drive on the left man...u prolly the only one usually in the car right?...it has nothing to do with box, well i dought it....it might be that ur tires are hitting ut fenders or are rubbing the plastic off on the inside of the fender
Old Nov 23, 2002 | 12:24 AM
RegRedTeg's Avatar
Im not that big but its only the rear left thats dropped that low, like almost on the tire and the other corners are a 1.5in drop.
Old Nov 23, 2002 | 12:08 PM
sauceman's Avatar
Take a look at your coil spring, it could be broken cold.
Trackready
Honda Civic (2006 - 2015)
Apr 27, 2013 08:09 PM
92_BlackSi
Oct 15, 2009 03:36 PM
RedHatch.eh
Mar 20, 2003 06:43 AM
jujubee
Apr 21, 2002 07:06 AM
Striker
Feb 1, 2002 02:56 PM
