trans / clutch (?) problem
Old Nov 23, 2002 | 12:58 AM
r4adkshn1's Avatar
Default trans / clutch (?) problem
okay. friend's car 92 vx with GSR engine & trans. We put an action 2MD (new bearings too) in. Bled the clutch. Car's on stands with axles and hubs/rotors on. With car shift lever in neutral, and clutch out, the passenger side will start spinning... forward I believe. When we push the clutch in it wont spin. The shifter will go in all gears fine, trans has fluid. Didn't check to see if it spinned while in gear (DOH!)...but just from that can you guys help in diagnosing the problem? appreciate it.
be
Old Nov 23, 2002 | 06:22 AM
b19coupe's Avatar
Default Re: trans / clutch (?) problem (r4adkshn1)
There may not be a problem, the wheels do spin in neutral on a lift.
Stock03Accord
Jul 5, 2018 05:24 AM
Vtec97
Dec 2, 2008 01:22 PM
LudeJdm
Nov 8, 2007 08:52 AM
92-EG6
Aug 25, 2003 10:02 PM
erikgsr
Apr 6, 2003 12:03 PM
