Electrical system's voltage is fluctuating?
Old Nov 22, 2002 | 02:45 PM
vtecprelude's Avatar
Default Electrical system's voltage is fluctuating?
I have 94 Prelude VTEC. After using Redline injector cleaner a few times, than out of no where when ever the car was in gear and in motion everytime I would step on the gas the voltage would drop along with that lots of hesitation...I take my foot off and voltage goes back up to 14v. The car is running extremely lean, the header is glowing red just after a short drive and plugs are white. It seems as though everytime injectros go online the voltage drops.
I've replaced many sensors along with alternator and nothing helped. When I disconnected ELD the voltage stayed normal at 14v and never drops, but hesitation is still there. I tried running the car by disconnecting the battarry, but when I hit 4k rpm the whole electrical system shut down, asthough something turned the alternator off. Should this be like this?
Has something happened to injectors causing the computer to malfunction? I even tried a different computer with no results.
Can anyone tell what is goin on with my car?
No check engine lights either, but SRS light is on due to a different reason.
[Modified by vtecprelude, 11:45 PM 11/22/2002]
[Modified by vtecprelude, 12:23 AM 11/23/2002]
BlackCatt
Jun 3, 2009 01:51 AM
K i l l a B e e.
Oct 20, 2008 03:00 AM
huge230
Aug 22, 2008 08:28 AM
Sportyballade
Oct 22, 2006 05:57 PM
Keith
Apr 5, 2005 09:43 PM
