My civic needs help?!?!!
Old Nov 22, 2002 | 06:34 AM
04eberra's Avatar
Default My civic needs help?!?!!
I have a 1993 honda civic and last night i went to turn my lights on and a fuse blew. My tail lights, license lights, bright lights, and dashboard lights went out, and my speedometer doesn't work. When i try to put a new fuse in it blows. Does anyone know what to do????
Old Nov 22, 2002 | 06:50 AM
Desslok's Avatar
Default Re: My civic needs help?!?!! (04eberra)
You have a short somewhere. Was anything installed recently, any modifications anywhere on the car? Possibly a screw shot through a wire somewhere.
Old Nov 22, 2002 | 08:11 AM
04eberra's Avatar
I had work done on my radiator the day it happened, I also installed a system(head unit, subs and amp)
Old Nov 22, 2002 | 08:22 AM
Desslok's Avatar
I'll bet it's a shorted wire somewhere. Most likely something with the stereo install. There is a dimmer wire that is in the stereo harness, probably shorted out. If you had it done somehwere I would take it back, if you did it trace all you r steps, look everywhere you ran wires or insalled something, and where you screwed the amp down, etc.
Old Nov 22, 2002 | 08:27 AM
teal_dx's Avatar
check your head unit wiring harness. there is one wire that u didnt need, i think it is the orange one. tape it up it is probably the one causing the short. I had the exact same thing
Amir_Ya_akov
Jul 22, 2020 04:11 AM
ilovemydc5
May 20, 2007 07:30 PM
Fiv3r-DA9
Mar 16, 2007 03:27 AM
brent_G
21
May 2, 2003 07:06 PM
