Squeaking Noise over speed bumps
Old Nov 24, 2002 | 08:58 PM
Maverick77's Avatar
Default Squeaking Noise over speed bumps
Everytime I go over a speed bump, my front end makes this squeaky/rubbery sound... it bugs the hell out of me. My friend that owns a shop says its my "Cheap Progress Camber Kit". Is it the camber kit or could it be my springs because they're just perched directly on the strut(I'm not sure if there should be anything between the strut and the spring).
Old Nov 25, 2002 | 04:15 AM
TeAm IllUsIonZ978's Avatar
Default Re: Squeaking Noise over speed bumps (Maverick77)
Wat kind of shock you got .. cuz i got some blue tokicos and the started to make noise the same way your explaining it .. and im going send them out and get white ones (5 way adjs)
Old Nov 25, 2002 | 08:18 AM
advanracing62's Avatar
Default Re: Squeaking Noise over speed bumps (TeAm IllUsIonZ978)
could also be your bushings
Old Nov 25, 2002 | 09:54 AM
Lord Quaalard's Avatar
Default Re: Squeaking Noise over speed bumps (advanracing62)
Definetly bushings, probably on the front sway bar.
I'd WD-40 them. But I'm sure someone else has a better idea.
Old Nov 25, 2002 | 11:38 AM
Maverick77's Avatar
Default Re: Squeaking Noise over speed bumps (MrDurden)
Shouldn't I just grease them up? Would I need to do an alignment again?
Old Nov 25, 2002 | 11:43 AM
shouldn't need an alignment, just put/spray a little lube on em and see where it takes you.
Old Nov 25, 2002 | 01:38 PM
sauceman's Avatar
Grease, don't lube with w40 or any thing like that, it'll only make things worst, believe me!!!
Old Nov 25, 2002 | 01:51 PM
GTRVspecII's Avatar
Default Re: Squeaking Noise over speed bumps (sauceman77)
TRU.. dont use cheap **** like WD40 .. grease bushings , and tighten everything.. if you have a loose part its probably not good to be drivin around on it.. and slow down over those bumps killer..
Old Nov 25, 2002 | 06:28 PM
IhateMy93BlackHatch's Avatar
Yea get the Tokico Illumina 5 point adjustable's. I had them on my car and the ride felt real good, i miss that car, there not cheap but there worth it
Old Nov 25, 2002 | 06:31 PM
Default Re: Squeaking Noise over speed bumps (IhateMy93BlackHatch)
and another thing i had that type of squeking before i did the whole suspension over, and never really figured out what it was, but after that the squeking was gone
Old Nov 25, 2002 | 07:35 PM
Maverick77's Avatar
I don't believe its my struts that is causing the problem though.
Old Nov 25, 2002 | 07:43 PM
PSIKOTICcrx's Avatar
i have this same problem, except it was after i installed my coilovers, it makes wierd noises when i turn the wheels
Old Nov 25, 2002 | 08:09 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Squeaking Noise over speed bumps (PSIKOTICcrx)
i think its bushings... happened to my friend's integra; i called bushings and it was the suspension bushings
Old Nov 25, 2002 | 09:05 PM
bokguay's Avatar
Default Re: Squeaking Noise over speed bumps (PreIudeSI)
most likely its the camber bushings
Old Nov 26, 2002 | 12:06 AM
thehondaguru's Avatar
Default Re: Squeaking Noise over speed bumps (bokguay)
I've got the same problem but it does it every time I hit a bump. I had my springs and camber kit installed professionaly. but still you never know.
JDMPR
Nov 18, 2009 09:41 AM
WildPig
Suspension & Brakes
63
Oct 27, 2005 12:05 PM
d16why
18
Oct 5, 2003 09:26 AM
thickfacek
Feb 9, 2003 09:08 AM
Maverick77
Nov 25, 2002 11:06 AM
