B16 timing cover (lower) on a GSR ?
Old Nov 21, 2002 | 07:29 AM
X2BOARD's Avatar
Default B16 timing cover (lower) on a GSR ?
Since I don't have either on hand, I can't compare.
But, again, trying to use parts from Honda rather than Acura for the obvious reasons. But I need a lower timing cover for my 96+ GSR motor (Don't know WTF happened to it !)
Will the timing cover from a B16 (99) fit on a B18 ? (please, I need an experienced response, not a guess)
Thanks
X2
Old Nov 21, 2002 | 12:13 PM
Kataku2K3's Avatar
Default Re: B16 timing cover (lower) on a GSR ? (X2BOARD)
I modified a B16A's to fit my friend's LSVTEC.... It didn't go straight over so i had to dremel a couple tabs off.. If you do have to modify it for you're GSR then I would recommend just buyin a new B18C one.... Just looks cleaner...
Old Nov 21, 2002 | 12:46 PM
Chugger's Avatar
Default Re: B16 timing cover (JDMspecEG6)
yes the lower cover from a b16 works fine that is what i am using on my b18c
then you will need a upper gsr cover to cover the whole thing
hope this helps
lata
chris
Old Nov 21, 2002 | 02:15 PM
CivicEK.PDX's Avatar
Default Re: B16 timing cover (Chugger)
It will work. Like Chugger said the top parts is the differences. Takes up the extra gap left behine by the taller block.
Old Nov 21, 2002 | 11:24 PM
X2BOARD's Avatar
Default Re: B16 timing cover (CivicEK.PDX)
Thanks fellas ! Luckily I sourced a B18C cover earlier today...
guedo148
Jul 8, 2009 07:22 AM
XKINGX
Apr 14, 2009 05:29 AM
C_Rock77
Sep 15, 2007 06:12 PM
agy2k2
Aug 4, 2006 03:52 AM
94TealGSR
Feb 4, 2003 03:46 PM
