Supercharged B20
Old Nov 24, 2002 | 08:21 PM
JDMs1eeper's Avatar
Default Supercharged B20
I was wondering if i supercharged my B20. Would it still be reliable or would i need to resleeve? I plan on running 6-8psi (which ever the kit comes with?) with basic bolt on adders...
ps: 38,000 miles on b20b motor (8.8:1 compression) and 50k on tranny... if this means anything
[Modified by Typesi2nv, 12:22 AM 11/25/2002]
Old Nov 24, 2002 | 09:16 PM
texan's Avatar
Default Re: Supercharged B20 (Typesi2nv)
It'll still be very reliable. The supercharger kits commonly available (I presume you are talking about a Jackson Racing kit) don't put that much additional stress on the engine.
Old Nov 25, 2002 | 06:32 AM
Jeff C's Avatar
I don't see any porblem with it.
I would do it without hesitation.
Old Nov 25, 2002 | 07:50 AM
1bad_EF's Avatar
From: On a pile of junked Acuras and Hondas, WI, usa
the b20 should handle that w/ no problem. Stay 6-8 psi for max reliability. However, that setup would have so much torque , you might be hurting performance w/ a gsr trans. The gears are to short and you would not be making the most of all that freeking torque. I would suggest you to try a ls trans. Usually, I tell people to throw those away, but in this case I have a feeling that you will go faster w/ a trans with longer gears.
Old Nov 25, 2002 | 08:30 AM
JDMs1eeper's Avatar
Default Re: Supercharged B20 (1bad_EF)
Thanks for the replys!, Yea I'm savin up to get the Jackson Racing kit. They have nice kits available and Ive heard nothing but possitive comments about them. So I'll go with JRSC. And YES lol torque is going to be crazy... but then again.. so am i haha THanks again for the replys
[Modified by Typesi2nv, 12:30 PM 11/25/2002]
Old Nov 25, 2002 | 09:02 AM
Jeff C's Avatar
Let me suggest one other thing......limited slip differential.
Trust me, you'll wish you had it.
Old Nov 25, 2002 | 12:37 PM
JDMs1eeper's Avatar
Default Re: Supercharged B20 (Jeff C)
yep. I was going to get a typeR LSD off ebay I already would benifit from having one! haha. thanks again
Old Nov 25, 2002 | 12:57 PM
Jammer's Avatar
You've obviuosly spent time on this engine was there a reason you chose not to go for a vtec head?
Old Nov 25, 2002 | 01:11 PM
Urban Business
Guest
Posts: n/a
Default Re: Supercharged B20 (Jammer)
fastest boosted hondas are non vtec. less rotational mass on the cams.
Old Nov 25, 2002 | 01:18 PM
Jeff C's Avatar
If I had it to do all over again, I would choose boost over vtec.
No technical reason for me. I just would.
Old Nov 25, 2002 | 02:35 PM
JDMs1eeper's Avatar
The Vtec head is a great project, but that I don’t have time or money for (tuning, building, ect) And I've always wanted to boost my car but a Turbo would be too expensive to get all the engine management I needed and tune it correctly. (Plus I don’t want that $500 header to be a waist! HaHa jk) The JRSC kit would give me all the power I needed with an easy install and great reliability without breaking the bank. I love the CRVtec and also Turbo but I can’t have all 3 so this is just the best choice for me. (Yes I know I could have 2 but I’ll remind you; this is my everyday driver and not my drag car ) But thanks for the question
Old Nov 25, 2002 | 03:09 PM
texan's Avatar
Default Re: Supercharged B20 (TorteX)
That's ridiculous IMO. Head airflow capability means so much more than the small difference in cam mass as to make such a claim pointless. By such reasoning, the single cam motors should then be just that much better than the DOHC motors.
Old Nov 27, 2002 | 09:27 AM
fredtoast's Avatar
Default Re: Supercharged B20 (texan)
I don't know about the mass of the cams, but the lift/duration doesn't make that big of a difference on supercharged engines. I have a supercharged 98 ITR, and you can hardly tell the difference at the VTEC changeover. When I was researching a new cam setup I was suprised to find that the lower duration/lift GSR cams would work best with the supercharger. It goes against my basic knowledge of engine performance, but that is what the experts say.
Old Nov 27, 2002 | 12:11 PM
1bad_EF's Avatar
Default Re: Supercharged B20 (fredtoast)
don't gsr cams have less overlap than ITR?
If so, when you pressurize the intake, wouldnt boost just go in and out and not really increase cyl. psi. which makes hp.
I might be wrong but this theory makes sense in my feeble mind
Old Nov 29, 2002 | 07:17 PM
iwhichisme's Avatar
ur car should still just as reliable as before. Ive seen them last with up to 12 psi, w/stock internals, w/o problems. So i wouldnt worry about tearing down your motor for 6-8 psi. happy boosting
peace,
chazz
Old Dec 2, 2002 | 11:08 AM
JDMs1eeper's Avatar
Default Re: Supercharged B20 (iwhichisme)
Cool thanks for the replys, I'm going to save though for a couple months, until like Feb. I wanna add all my exterior and engine aftermarket stuff at once but without useing all my funds up at once heh.. thanks again and i'll let yall know when i start boostin
Old Dec 2, 2002 | 11:34 AM
keebler65's Avatar
sounds like it'll be a sweet setup. be sure to post a dyno plot when you're done
Old Dec 2, 2002 | 12:40 PM
f0de's Avatar
Default Re: Supercharged B20 (keebler65)
turbo > supercharge
Old Dec 2, 2002 | 06:51 PM
JDMs1eeper's Avatar
Default Re: Supercharged B20 (f0de)
Jackson Racing Supercharger
Old Oct 28, 2020 | 01:04 PM
Yodėgan's Avatar
peace,
chazz
do you know how much power increase there is with these kits?
Old Oct 28, 2020 | 09:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
40-60 wheel HP increases are not uncommon with a B20 JRSC kit.
green gawd
Dec 21, 2007 01:55 AM
TEGPOWER44
Nov 19, 2002 08:07 PM
maxxdout
Oct 24, 2002 11:35 PM
silver89civic
Apr 12, 2002 05:27 PM
1fastcx
Dec 30, 2001 04:04 PM
