Compression test on stock b20vtec
Old Nov 20, 2002 | 10:59 PM
Norcalstoppy's Avatar
Default Compression test on stock b20vtec
I just did a compression test on my engine right now. ( Yeah I know it's midnight, but i got bored) And here is the result:
187-187-190-192
My setup is jdm b20b w/ b17 head. What would be the approximate CR depending on these compression numbers?
Jay Kim
Old Nov 20, 2002 | 11:23 PM
Kamin's Avatar
Default Re: Compression test on stock b20vtec (AllMotorMonster)
dont know about the EXACT numbers but yours looks fine.
there are too many variables to say "it should be between x and y if its not somthing is wrong"
when you do a compression test its mostly just to make sure all 4 cylinders have the same compression. yours look great.
Old Nov 20, 2002 | 11:25 PM
Default Re: Compression test on stock b20vtec (KAMiN)
Thanks.
Well, I was just wondering, in a ideal situation, what would a GSR, Si, and ITR engines put out on compression tests?
Jay Kim
Old Nov 20, 2002 | 11:42 PM
Kamin's Avatar
mine is mid 180's across the board. second gen b16.
Old Nov 21, 2002 | 10:00 AM
any other cars with compression numbers?
Jay Kim
Old Nov 21, 2002 | 12:55 PM
Doogie Howser's Avatar
gsr's are around 220 itrs are around 230, but really the numbers can vary widely it just matters if all you numbers are within about 5
self_made
Jun 19, 2005 12:36 PM
Mr.Integra
Apr 22, 2004 07:55 PM
2old_honda
Apr 12, 2002 01:25 AM
MechEng
Feb 11, 2002 06:15 PM
