coolant path question
Old Nov 22, 2002 | 07:37 AM
nafreak's Avatar
Default coolant path question
Does anyone know the direction the coolant flows through the FITV?
Does it come out of the intake manifold flow through the FITV then through the IACV and then into the block?
OR vise versa?
Its a 92 GSR with the stock B17A
Old Nov 22, 2002 | 12:19 PM
577HondaPrelude's Avatar
Default Re: coolant path question (nafreak)
Yes, what U said is the way it is on stock setup. But if U hook it up vise versa no big deal, it will still work.
Old Nov 23, 2002 | 01:23 PM
nafreak's Avatar
Default Re: coolant path question (57STS)
Thanks for the reply.
Then it means that more than likely then my FITV is bad then. I was hopeing that it wasnt getting any coolant from a hose that I pinched off the other day cleaning my IACV.
hmmnnnn......
Old Nov 25, 2002 | 08:45 AM
nafreak's Avatar
can you clean the FITV like we have to clean the IACV sometimes?
I havent taken it off yet.....
TIA!
Old Nov 25, 2002 | 09:02 AM
Desslok's Avatar
Check the end of this out:
http://www.smpcorp.com/download/view/TT2Q98.PDF
Old Nov 29, 2002 | 12:10 PM
nafreak's Avatar
BTW: I went out there and cleaned the FITV today and it has its own coolant feeding lines and IS NOT connected the IACV like I thought it was. When I asked the question I hadnt looked @ it very well and it seemed as thought it was connected, but it was another coolant line that was very close to it.
quikflip27
Mar 4, 2009 11:10 AM
Cypher0117
18
Sep 29, 2005 07:46 PM
eL
Sep 23, 2004 06:25 PM
chri5
Jun 26, 2001 03:57 PM
