valve train
Old Nov 21, 2002 | 06:45 PM
JDMCIV95's Avatar
Default valve train
i am wanting to build a NA b16. which vavle springs, retainers, and cams should i use? where can i get my ecu reprogamed to have a higher redline? and how high could i rev with the spings, retainers and cams?
Old Nov 22, 2002 | 07:47 AM
advanracing62's Avatar
Default Re: valve train (JDMCIV95)
depends on how much $$ you want to spend. Having a super built head isn't going to be all that great unless you spend a bit in the block. I run JUN III cams and the full valve train. So far I've revved to 10k repeatedly, no problem. You'll get a lot of variance here on who is better than who, it's all BS. Just look at the dyno charts, listen to people who tune (or those who will tune your car) and then make your decision. You can run Hondata, or chip an ECM to get your RPM band to go up. If you want a chipped ECM I think Kenji can do it for you, hell practically anyone can do it these days.
krc91987
11
Jan 18, 2012 07:35 AM
406Honda
Aug 23, 2010 12:25 PM
lowsiciv
Nov 28, 2006 12:27 PM
Waachback
11
Aug 10, 2004 02:41 AM
metal-x
Jan 22, 2002 05:28 AM
