vehicle speed sensor is not working properly....
Old Nov 21, 2002 | 05:00 PM
mattt's Avatar
Default vehicle speed sensor is not working properly....
My vehicle speed sensor is not working properly 97 sedan with b16a2 swap. The speed fluctuates (spelling?) alot, sometimes it does not function at all. I get a cel too.
Does a faulty vss affect anything else than my speedometer? Should I replace it asap?
What should I check first?
*** removed from eg+ ***
Old Nov 21, 2002 | 08:53 PM
tinkerbell's Avatar
Default Re: vehicle speed sensor is not working properly.... (mattt)
it would affect your VTEC. ie it would not work.
does you ECU throw any codes - is it a Code 17?
if so, you should replace teh VSS to get VTEC back on
t..
Old Nov 26, 2002 | 07:20 PM
mattt's Avatar
Default Re: vehicle speed sensor is not working properly.... (tinkerbell)
vtec works fine... i'll check my code
Old Nov 26, 2002 | 08:03 PM
Kataku2K3's Avatar
Yea if you got a code for ur VSS then barrow a friend's or something and see if it works fine before you go buy one... If it's still bad after there maybe some problem in your wiring.. Good Luck
radiotech
Apr 21, 2018 09:43 PM
supra-n-civic
Jun 23, 2009 07:01 AM
DumpedSi
Sep 8, 2003 04:18 PM
HaUTSaauce
Mar 31, 2002 11:04 AM
HaUTSaauce
Mar 30, 2002 07:12 PM
