check engine light on when V-tec engages
Old Nov 22, 2002 | 05:15 PM
denshu's Avatar
Default check engine light on when Vtec engages
The check engine light comes on after i do Vtech a couple of times and stays on untill i shut off the car and restart it. When i restart it it goes off! does anyone know whats wrong?
This only happend when I changed my oil
i used mobile1 super synthic blend 5w30
[Modified by denshu, 6:15 PM 11/22/2002]
[Modified by denshu, 6:16 PM 11/22/2002]
[Modified by denshu, 6:47 PM 11/24/2002]
Old Nov 22, 2002 | 05:17 PM
punzak's Avatar
Default Re: check engine light on when V-tec engages (denshu)
I got that when my knock sensor was fried.
Old Nov 22, 2002 | 05:23 PM
denshu's Avatar
Default Re: check engine light on when V-tec engages (punzak)
oh yea and the motor is a jdm b16
Old Nov 22, 2002 | 07:12 PM
denshu's Avatar
anyone know what happend?
Old Nov 22, 2002 | 07:29 PM
Chiovnidca's Avatar
What code?
Old Nov 22, 2002 | 08:16 PM
mugenracer's Avatar
Default Re: check engine light on when V-tec engages (Chiovnidca)
same thing used to happen to me when my o2 sensor died..get the code first
Old Nov 23, 2002 | 04:37 AM
ninesecrx's Avatar
Default Re: check engine light on when V-tec engages (mugenracer)
Good chance its an oil pressure if it only comes on when it comes on when it hits vtec. Get the code though and that will tell us for sure.
Old Nov 23, 2002 | 10:03 AM
Ryu's Avatar
Ryu
Default Re: check engine light on when V-tec engages (ninesecrx)
i get this too after i engage vtec once in a while...
code i get is 12 and 14... i think its because i didnt hook up my EGR vaccum into the TB... and their aint enough lift... forgot what the other code is telling me but
Old Nov 23, 2002 | 04:46 PM
-Whitey-'s Avatar
Default Re: check engine light on when V-tec engages (Ryu)
my car does that because of the knock sensor
Old Nov 23, 2002 | 06:52 PM
Racerj404's Avatar
dont spell VTEC, (V-tec or V-tech), i did this the other day and still get ripped on, just thought i would let you know.
[Modified by Racerj404, 4:55 AM 11/24/2002]
Old Nov 24, 2002 | 11:33 AM
denshu's Avatar
Default Re: check engine light on when V-tec engages (Racerj404)
ok i tried to check for a code but it didnt' give me any?
could it be the oxygen sensor?
Old Nov 24, 2002 | 12:45 PM
Chiovnidca's Avatar
How are you checking for the code?
Old Nov 24, 2002 | 12:48 PM
satan_srv's Avatar
Sounds like the VTEC oil pressure switch. Do you have a V-AFC?
Old Nov 24, 2002 | 02:13 PM
denshu's Avatar
Default Re: check engine light on when V-tec engages (satan_srv)
no i don't have V-afc
i checked it by looping the terminals at the passanger side of the car with a paper clip... o o o like that? did i do it right? then i put it to the on position.
I____I
no engine light.
my check engine light only goes on when i vtec it in 3rd gear then if i shut the engine off and turn it back on, it's gone
Old Nov 24, 2002 | 02:29 PM
Chiovnidca's Avatar
I____I
no engine light.
Are you jumping the 2pin connector, or the 3 pin connector?
Old Nov 24, 2002 | 02:36 PM
denshu's Avatar
the 3 pin connector
Old Nov 24, 2002 | 02:50 PM
Chiovnidca's Avatar
the 3 pin connector
Jump the 2-pin connector, that should work a little better.
Old Nov 25, 2002 | 10:51 AM
denshu's Avatar
Ok i got the codes
it went 6 short times
then 7 short times
then 1 long time
then 1 long one again
and 1 short one
06 Engine Coolant Temp circuit ?
07 Throttle Position circuit Reading too low or too high, open or short in circuit, defective TPS circuit ?
21 VTEC Solenoid Valve Open or short in VTEC solenoid valve circuit, defective VTEC solenoid valve ?
do i replace all of those?
[Modified by denshu, 2:19 PM 11/25/2002]
Old Nov 25, 2002 | 01:55 PM
GTRVspecII's Avatar
Default Re: check engine light on when Vtec engages (denshu)
Check out your O2 sens. .. also sumtimes sensors fry outta nowhere so check all your comp. stuff out and get back to us.. cheers
36Chitownrunnin
Jun 17, 2008 08:44 PM
racingant
Aug 12, 2005 05:12 PM
jagojon3
Jun 29, 2005 03:17 PM
Renegade
Aug 9, 2002 11:09 PM
boosted spoon
Jul 23, 2002 12:08 PM
