speedometer doesnt work...
Old Jan 15, 2005 | 01:02 AM
scUba-stEve's Avatar
Default speedometer doesnt work...
okay i just built my motor and put it in...the speedometer doesnt work, and if i drive for a while the CEL comes on, and of course it's code 17...i've been searching and found that there's speedo cables, but are these cables just for '91 and older cars? cuz i have a '94 civic ex, and i'm pretty sure the vss is electronic...just making sure that the 5th gens dont have speedo cables.
Old Jan 15, 2005 | 08:20 AM
primeredbeast's Avatar
Default Re: speedometer doesnt work... (b20vtecTURBOnos)
on the back of the tranny there is a sensor you either broke it or it's not plugged in
Old Jan 15, 2005 | 11:10 PM
PrettyLude's Avatar
check and see if the vss has good contact points, sometimes moisture or water gets in there
Old Jan 18, 2005 | 06:49 PM
Default Re: (PrettyLude)
can someone show me how to wire the vss plug straight to the ecu?...i wanna try this before i cut up my engine harness to solder the new plug on (just in case the plug wasnt the problem, i dont wanna mess up my harness for no reason)...thanks in advance.
Old Jan 22, 2005 | 11:37 AM
usfsfirefighter0's Avatar
Default Re: (b20vtecTURBOnos)
when find out let me know?
Old Jan 23, 2005 | 07:25 PM
Default Re: (usfsfirefighter0)
well...i never ran the wires straight to the ecu, and just took a chance on cutting the plug off and soldering in the new plug...and guess what? it works now...i just matched up the colors of the wires and "voila"...it worked...i guess my old plug was pretty rusted up.
yungmulacrx
Aug 21, 2011 07:53 AM
2ndchirp
Dec 28, 2009 09:54 AM
dohc_profile
Mar 3, 2009 05:42 AM
Banjo the Ninja
Sep 4, 2008 10:38 PM
Bartman201
Sep 3, 2005 06:35 PM
