GSR clutch... or tranny issues?
Old Jan 11, 2005 | 08:17 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default GSR clutch... or tranny issues?
i don't want this be be another generic "do i need a clutch" question.. but im trying to narrow it down, and figure out what the hell is going on.
1st of all, its a 97 GSR, origonal OEM clutch with 150K.. DOES NOT SLIP.. but it does feel stiff.. stiffer than other OEM cluthces. So im wondering if my clutch is due... when i shift, it wants to lock me out of gear. unless i shift at 2-2500 RPM, anything higher than that, it wants to lock me out. ive adjusted the clutch throw with the rod that goes into the clutch master.. and ive also changed the tranny fluid over to GM snyncromesh.
It does NOT GRIND any gear, like its synro's.. so im lost. a friend of mine mentioned the fact the clutch disk could be still spinning, and this is why its locking me out? any other ideas?
do worn out springs in the clutch disk, or pressure plate cause lock out issues?
Old Jan 12, 2005 | 07:05 AM
JimBlake's Avatar
Default Re: GSR clutch... or tranny issues? (Built B16A)
Sorta sounds like a dragging clutch. Or maybe a pilot bearing getting stiff. So your clutch doesn't 'completely' disengage, and your synchros block you out of the gear you're going for. Good synchros block you out of gear when the revs don't match. Bad synchros let you thru (grind).
Old Jan 12, 2005 | 12:30 PM
Built B16A's Avatar
Default Re: GSR clutch... or tranny issues? (JimBlake)
yeah, im banking on a clutch... its alot cheaper than tranny work.
Old Jan 14, 2005 | 12:45 PM
clayne's Avatar
No. But broken spring retainers on GS-R clutches do.
It's a known defect in almost all OEM Honda GS-R clutches. I've had 2 clutch discs fail on me before getting an ACT clutch. One was a 94, the other a 97.
vteckyle
Jan 8, 2008 11:45 AM
tianporn
Nov 5, 2004 12:18 PM
turboteg96
May 21, 2003 05:46 AM
Leo95SE
Aug 18, 2002 07:17 PM
