Need help. Coolant lines + more. Already searched
Old Jan 18, 2005 | 11:22 AM
adictionbass's Avatar
Default Need help. Coolant lines + more. Already searched
Having some trouble, i searched for about hlaf an hour and didnt get very much. Engine is a 97 b18c1. I have a helms but its for a b16A3 and mine is really different.
Need to know where these all go.
There are 2 lines on the Big water connecting hose on the back of the block.
There is only 1 big line on the Thermo. I know this goes to the head through the intake manifold.
There is 2 ports on the IACV which one goes where?
There is 2 ports on the bottom of the throttle body, one facing the firewall, and one facing forward.
There is one port off the top of the coolant inlet where the coolant comes from the radiator. and there is one smaller one right beside it.
Other question, when running a catch can, are you really supposed to just fill the 1.5" hole where the black box was with hondabond?
Thanks for any help guys, wish i could get pics up....
Old Jan 18, 2005 | 11:59 AM
Default Re: Need help. Coolant lines + more. Already searched (adictionbass)
think i figured it out, someone tell me if this sounds right.
The smaller line from the water hose going to the IACV, then to the back of the throttle body, then out the front of the throttle body and connects to where the radiator hose connects to the motor. Yes?
Old Jan 18, 2005 | 01:53 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">think i figured it out, someone tell me if this sounds right.
The smaller line from the water hose going to the IACV, then to the back of the throttle body, then out the front of the throttle body and connects to where the radiator hose connects to the motor. Yes? </TD></TR></TABLE>
your correct
Junesong
Feb 5, 2009 09:52 AM
XSIintegra
Aug 27, 2008 06:03 PM
done
Oct 14, 2005 12:24 PM
t3to4e
Dec 24, 2003 10:56 AM
xlerate93
Jul 14, 2003 09:48 AM
