Throwing Codes 7 and 14- Need Help
Old Jun 12, 2005 | 02:03 PM
vtecb20coupe's Avatar
B A N N E D
Default Throwing Codes 7 and 14- Need Help
just installed the motor and the car will not rev past 2k, and struggles to get there at the 1.5k point. originally had an aebs manifold on there, which i thought the problem might be. swapped it back with the stock b16 and still the same problem. i've even swapped the throttle body with a known working one with all sensors, but still came across the same issue. also, the car idles rough and high when it's cold and then all of a sudden will drop down to normal idle speed out of the blue.
now, my question is this, could it be the tps, wiring, or just possibly the ecu? it's running off of a chipped p28. it's a 92 civic with ls/vtec, if anyone needs to know. this is driving me nuts 'cause before the motor was torn, it rev'd just fine.
any help is appreciated!
Old Jun 12, 2005 | 06:33 PM
Chiovnidca's Avatar
Default Re: Throwing Codes 7 and 14- Need Help (vtecb20coupe)
Is it possible your TP and IAC connectors are switched?
Old Jun 12, 2005 | 07:32 PM
PrettyLude's Avatar
Default Re: Throwing Codes 7 and 14- Need Help (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible your TP and IAC connectors are switched?</TD></TR></TABLE>
Old Jun 13, 2005 | 04:08 AM
B A N N E D
nope. already checked that. you can tell immediately once the car is cranked whether or not the two are switched. the car idles fine when warm, just can't rev past 2k.
any other ideas anyone?
Old Jun 13, 2005 | 09:17 AM
B A N N E D
anyone for the midday lunch hour?
also, found this link that i will try out tonight but if this doesn't work, any other suggestions?
https://honda-tech.com/zerothread?id=1231548
Old Jun 13, 2005 | 02:15 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">
any other ideas anyone?</TD></TR></TABLE>
Have you checked out the TP and IAC circuits? Gotta be something pretty f-ed up if it wont rev over 2k.
Old Jun 13, 2005 | 02:17 PM
B A N N E D
when you say circuits, what exactly do you mean? please clarify.
b20vtech
Aug 30, 2008 09:09 PM
wuchang
15
Feb 12, 2008 09:47 AM
TYPErCRX
Jul 4, 2005 02:45 PM
808_eG_unit
May 22, 2005 08:06 PM
Squirtin EGsr
Feb 23, 2004 04:08 AM
