Can compression keep your car from starting??
Old Jun 7, 2005 | 09:06 AM
blacksihatch's Avatar
Default Can compression keep your car from starting??
I have a b16 and i replaced the rings and put in valve spring and titnm retainers
and tried starting the car no luck.. cheked the compression and all cyl were 140psi then took it all apart and put in the old valves it went to 160psi ...now keep in mind before i did anything the psi was 205-210 per cyl....
Im going to do a valve job so the valves seat better and test and try to start it again but the car does have all whats needed to start a car air, spark, and gas
but does the compression need to be higher to start or how high does it need to be to start....or do you have any other ideas (trouble shooting) that i can use to help
the engine just continues to turn and turn and turn
Old Jun 7, 2005 | 01:54 PM
Chiovnidca's Avatar
Default Re: Can compression keep your car from starting?? (blacksihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksihatch &raquo;</TD></TR><TR><TD CLASS="quote"> does the compression need to be higher to start or how high does it need to be to start.... </TD></TR></TABLE>
Over 100psi should be fine to get started. Sure you have your cams properly timed?
Old Jun 7, 2005 | 02:04 PM
Default Re: Can compression keep your car from starting?? (Chiovnidca)
yea i do, the crank is at top dead center an the cams are alined as they should i dont really understand
what else could it be ...again the engine keeps turning and turning
Modified by blacksihatch at 2:43 AM 6/8/2005
mrportugal4
Jun 18, 2010 11:42 AM
honda_prelude_jay
Jan 3, 2009 03:36 PM
Under Con. CrX
Feb 20, 2008 10:20 PM
geezer06
Oct 26, 2003 04:43 AM
FuzzyGreen
Jan 22, 2002 05:24 PM
