B18C1 Engine Specs Official Honda
Old Jun 6, 2005 | 04:17 PM
Yambor's Avatar
Default B18C1 Engine Specs Official Honda
These are the specs for the B18C1 GSR Motor. Just to clear all confusion. This thread can be locked and added to any forum. Im sure this thread will be looked upon for clearances, oil capacity, etc....These ARE specs from Honda. I also have specs for the B16, and B18B i can post if needed..
Component Torque/Ft. Lbs.
A/C Compressor 17
Alternator 17
Alternator Bracket 33
Back Cover 9
Camshaft Pulleys 27
Cooling System Bleed Bolt 7
Crankshaft Pulley [02]
Cylinder Head Bolts [03]
Distributor 16
Engine Mounts [04]
Exhaust Heat Shield 7
Exhaust Manifold Bracket to Engine 33
Exhaust Manifold Bracket to Manifold 33
Exhaust Manifold Nut 23
Exhaust Manifold Shroud 17
Exhaust Pipe 16
Fuel Filter Banjo Bolt 25
Fuel Filter Service Bolt 11
Fuel Pump Nut 4
Intake Manifold Bracket 17
Intake Manifold Nut 17
Oil Drain Plug 33
Oil Filter 16
Oil Pan 9
Oil Pump [01]
Oil Screen 8
Oxygen Sensor 33
Power Steering Bracket 33
Power Steering Pump 17
Radiator Bracket 7
Right Side Cover 8
Speed Sensor 9
Throttle Body Bolts 14
Timing Belt Adjusting Bolt 40
Timing Belt Cover 9
Transaxle Mounts [04]
Valve Adjusting Locknut 18
Valve Cover Crown Nut 7
[01] -- 6 x 1 mm bolts, 8 ft. lb; 8 x 1.25 mm bolts, 17 ft. lbs.
[02] -- Tighten pulley to 145 ft. lb, loosen bolt, then tighten to 130 ft. lbs.
[03] -- Refer to Cylinder Head Assembly for tightening procedure.
[04] -- Refer to Engine for proper tightening torques.
This is for those who do not have a helms or haynes, and for quick reference. Hope this helps some people.
ODbuilt
Nov 23, 2013 07:03 PM
GeneBEllis
May 9, 2013 08:16 PM
Scotty2H
Dec 13, 2007 10:54 AM
phantomcow2
Jul 30, 2007 05:36 PM
