problem with rpms after shifting
Old Jun 11, 2005 | 05:22 PM
xDiMSuMx's Avatar
Default problem with rpms after shifting
hey guys, got a problem and i can't figure out how to fix it
when i shift at redline, my rpms drop slowwwly until it catches around 5000
it's supposed to drop down right away
this usually only happens when i have under half tank of gas
car hesitates sometimes too
this is in the low rpms when i go from a stop
i changed the fuel filter in the winter and seemed to fix the hesitation problem but it's back again now
could the clogged fuel filter cause my fuel pump to start failing like this?
Old Jun 11, 2005 | 05:47 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: problem with rpms after shifting (xDiMSuMx)
What car and transmission do you have?
Old Jun 11, 2005 | 08:20 PM
xDiMSuMx's Avatar
Default Re: problem with rpms after shifting (Dogginator)
91 crx si
sohc zc
Old Jun 12, 2005 | 01:11 AM
NITROUSHONDA's Avatar
check your fuel pressure to see if that is your problem
Old Jun 12, 2005 | 07:17 AM
Dogginator's Avatar
Daisy... Daisy...
The fact that your RPM drops slowly after a shift if strange. You would think that insufficient fuel would make it drop faster than usual. Has you fuel mileage dropped recently? Have you checked for vacuum leaks?
Old Jun 13, 2005 | 03:22 PM
xDiMSuMx's Avatar
for mileage i get around 550 km on a tank
not sure what it is in mpg
any tips on how to check vacuum leak?
Old Jun 13, 2005 | 03:31 PM
xDiMSuMx's Avatar
oh i'm also putting on my turbo this weekend
can i go ahead with that or should i wait until this is all fixed?
might make me run lean?
Old Jun 13, 2005 | 04:34 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDiMSuMx &raquo;</TD></TR><TR><TD CLASS="quote">for mileage i get around 550 km on a tank
You can carefully listen for a hiss.
Or...
You can spray some (not much) carburetor cleaner around the vacuum lines and the intake manifold while the engine is running. Listen for an idle surge.
Or...
Start the car with the air intake removed from the throttle body. Seal the throttle body with you hand. If the car keeps running, you have a leak.
Old Jun 13, 2005 | 04:38 PM
xDiMSuMx's Avatar
thx dogginator
i'll try it tonight and tell u how it goes
Old Jun 14, 2005 | 03:14 PM
xDiMSuMx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Or...
Or...
Start the car with the air intake removed from the throttle body. Seal the throttle body with you hand. If the car keeps running, you have a leak. </TD></TR></TABLE>
coudln't hear a hiss except coming from the intake
don't think i can use the carb cleaner thing because my idle is surging anyways
covered the throttle body and the car just turned off
Old Jun 14, 2005 | 04:06 PM
Dogginator's Avatar
Daisy... Daisy...
Surging idle can also be caused by a vacuum leak. Have you tried to set your idle recently? Have you made any changes to the fuel or air systems?
Old Jun 14, 2005 | 06:33 PM
xDiMSuMx's Avatar
i did try to set my idle a bit higher but the problem was happening way before that already
no changes to fuel or air recently
i have an intake and exhaust
i'm actually putting on my turbo this weekend and was hoping to get it fixed up by then
350TPI
Jul 27, 2009 05:17 AM
Martaigne
Jul 31, 2002 05:08 PM
