car not starting..... lil help?
Old Jun 11, 2005 | 04:01 PM
92hatchattack's Avatar
Default car not starting..... lil help?
ok, heres the whole deal. Im doing my junkyard setup, and ive got the std mani with turbo and oil lines bolted on... waiting on charge piping ....
So i start up my car today and the **** is ******* missfiring and smoking like a mother ******! Im like WTF! ok .. so i go through the basics.
Compression test.. 190 across.... pull plugs.. there black.... put new plugs in .. no good .. **** with dizzy .. no help ...
finally im looking around and i notice that my damn vac line is off my wall mounted map sensor .. Ok i plug that **** in and walla, smoke is gone and idles good..
Car still had a little bit of a hiccup in it, so i shut it off, and turned the dizzy bnack a little bit to stock timing . Fire it back up, and its runs fine for like 5 seconds and then just hardcore cuts the **** out on me. And thats where i sit now, Hasnt fired since then.
Anyone have any ideas about what the hell could have happened? I mean i didnt like stuble and stall out, it was like it just kicked right out as if i had turned off the key! .. Im lost....
Old Jun 11, 2005 | 04:08 PM
Kendall's Avatar
Check everything again. Also check to make sure that the turbo isn't siezed.
Old Jun 11, 2005 | 04:32 PM
how would siezing my turbo keep my car from starting???
i doubt its seized, it was in good shape and it was just at idle .. but ill check, unfortunatly i dont get to work on it again till next weekend
keep the sugestions coming though!
BlackHonduh
Mar 8, 2008 04:05 PM
TcUiRvBiOc
Aug 12, 2007 08:01 AM
1crx2nv
May 10, 2006 08:13 PM
FOrSfEd
Nov 13, 2003 09:39 PM
r2x
40
Oct 2, 2002 06:28 AM
