Engine knocking, but internals look fine.
Old Jun 12, 2005 | 12:24 PM
doublejz's Avatar
Default Engine knocking, but internals look fine.
Ok so my motor was knocking really bad. I thought it was rod slap or a blown bearing. So I ripped it down today and everything looked perfect (pretty much). The only things that I saw that wearing weird were 2 main caps and 1 rod bearing was worn and the rest weren't. The knocking was coming from the furthest cylinder on the drivers side. oil pressure was 27 at idle and close to 80 at WOT.
Main Cap
Another Main Cap
Rod Bearing from the cylinder that was making noise
rod cap from the cylinder that was making noise.
I really don't see anything that would cause the knocking.
Oh heres something else interesting. Below are 2 pics where the water pump goes. In the square/rectangular hole (not where the actual spinning apparatus for the pump goes) you can see scratches, chips that look new. What could have cause these? or do you think it was from when the block was put together back in the day?
Old Jun 12, 2005 | 02:02 PM
stevenlo's Avatar
Default Re: Engine knocking, but internals look fine. (doublejz)
check to make sure the pistons aren't touching the head in any way...
Old Jun 13, 2005 | 12:23 PM
doublejz's Avatar
bump
Old Jun 15, 2005 | 03:51 AM
doublejz's Avatar
nope, wasnt hitting the head. the knock was coming from the bottom end by the crank pulley.
Old Jun 15, 2005 | 05:33 AM
mmuller's Avatar
Mad Scientist
so do your tolerances check fine?
Old Jun 15, 2005 | 10:32 AM
doublejz's Avatar
Default Re: Engine knocking, but internals look fine. (mmuller)
yea. its at the shop now, they said everything looks good :-/
Old Jun 15, 2005 | 02:50 PM
allmotorSOHC16's Avatar
those look like what my bearings looked like. everything spec'd out ok and i put it back together. i think the bearings had warped due to added friction from low oil. i out new bearings in and everything seems fine now.
Old Jun 15, 2005 | 03:03 PM
mmuller's Avatar
Mad Scientist
Default Re: (allmotorSOHC16)
the rod bearings look like the have had normal abuse.
the mains look like the bearing had improperly seated
Old Jun 16, 2005 | 06:08 AM
doublejz's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">the mains look like the bearing had improperly seated</TD></TR></TABLE>
that's what i was thinking too. everything looks surprisingly good, has around 80,000 miles on it.
Jaycrv
Honda CR-V & Element
Jul 8, 2017 02:22 PM
IVAN93EG
Jun 24, 2006 09:27 PM
Killersohc
Nov 22, 2005 06:31 PM
Drew Peacock
Aug 9, 2004 09:24 PM
shannon
Dec 21, 2003 07:43 AM
