Engine Building Techniques
Old Jun 7, 2005 | 03:41 PM
calizum's Avatar
Default Engine Building Techniques
Is there any way during an engine build, to ensure that after it is all complete, to be positive that you will not spin a bearing during the course of break in, and after?
Old Jun 7, 2005 | 06:54 PM
PrettyLude's Avatar
pay careful attention to your oil
Old Jun 7, 2005 | 07:45 PM
drdisco69's Avatar
Default Re: (PrettyLude)
Clean everything very well. Keep everything organized. Triple check all your clearances for oil. If you have ANY doubt about the ability for a component to hold a bearing, ie. welded crank or "slightly" spun rod, give it the water test: throw it in a lake, if it floats, it's ok to use.
Old Jun 8, 2005 | 07:29 AM
jdm123's Avatar
Default Re: (drdisco69)
plastigauge it or use a dial bore gauge(?) to measure the clearances between the bearing and the rod.
Old Jun 8, 2005 | 07:35 AM
tgreaves's Avatar
Default Re: (jdm123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 &raquo;</TD></TR><TR><TD CLASS="quote">plastigauge it or use a dial bore gauge(?) to measure the clearances between the bearing and the rod.</TD></TR></TABLE>
Or do both just to check yourself..
Old Jun 8, 2005 | 07:36 AM
Kendall's Avatar
Don't consume any alcohol before assembling the motor.
RACEPAK
Welding / Fabrication
Dec 11, 2010 06:21 PM
pjr710
Aug 20, 2008 01:03 PM
Nisif
Jul 27, 2006 05:41 AM
Dyzee
10
Apr 28, 2004 11:56 AM
eghonda
Nov 28, 2003 09:50 AM
