swapping built ls...problem with rear tranny bracket
Old Jun 5, 2005 | 09:56 PM
airwalk07143's Avatar
Default swapping built ls...problem with rear tranny bracket
im swapping my built and sleeved ls motor into my crx... i got it bolted it but i cant get the rear tranny bracket to bolt up cause it such a tight fit. it there any special trick or sumthing... also anyone know where you can but the place racing front crossmembers?
Old Jun 6, 2005 | 09:44 AM
mastarolla's Avatar
Default Re: swapping built ls...problem with rear tranny bracket (airwalk07143)
keep working with it...i guarantee it fits because i run into adjusting the motor around to get the mounts to all line up everytime.
Try using a jack under the motor to slightly lift up and if needed, undo one of the side mounts from the frame. I usually wind up with enough play to be able to line up the rear that way.
boomersz
10
Mar 8, 2007 07:34 AM
boomersz
Mar 5, 2007 04:08 PM
98civic94gsr
Dec 21, 2004 07:44 AM
See Are X
Dec 1, 2002 09:58 PM
