oil in b16
Old Jun 11, 2005 | 10:19 AM
Suck my DX's Avatar
Default oil in b16
how many quarts does a b16 hold....the reason i ask is because i filled up with 4 quarts when i changed my oil and now im having vtec problems....it engages good in 1st gear...kinda fumbles then takes off in second...and third has no vtec at all..like u hear it crossover and it feels like it wants to go but it just bucks n bangs....my oil pan is bent up a lil too...would this have any affect...thanks
Old Jun 11, 2005 | 11:06 AM
HoUTX98GSR's Avatar
Default Re: oil in b16 (Suck my DX)
a bent oil ban CAN cause vtec not to engage.. but who knows if thats your problem.. test the selonoid.
Old Jun 11, 2005 | 11:34 AM
Suck my DX's Avatar
Default Re: oil in b16 (HoUTX98GSR)
how many quarts does b16 hold though..thats my main question..i was always thinking 4
Old Jun 11, 2005 | 11:42 AM
HoUTX98GSR's Avatar
i thought all b series took 4... or 4.3 not sure though, sorry.
Old Jun 11, 2005 | 12:30 PM
Padawan's Avatar
Darth ModerVader
What does the dip stick indicate?
When I do an oil change, I never simply add a specific amount and close it up. Instead, I add a little less than what's listed in the manual, then check the dip stick, add a small amount more, check again, etc., until it is at the correct level.
Old Jun 11, 2005 | 02:35 PM
Suck my DX's Avatar
Default Re: oil in b16 (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">What does the dip stick indicate?
When I do an oil change, I never simply add a specific amount and close it up. Instead, I add a little less than what's listed in the manual, then check the dip stick, add a small amount more, check again, etc., until it is at the correct level. </TD></TR></TABLE>
well it looks just right on the dipstick...im guessin that it as something to do with my oil pump...vtec just aint working correctly in all gears
Old Jun 11, 2005 | 07:26 PM
turbo_b16_ex's Avatar
check your vtec solenoid. three bolts gold it together. You could have a bunch of gunk plugging the screen on it.
Old Jun 12, 2005 | 12:49 PM
Suck my DX's Avatar
Default Re: (turbo_b16_ex)
i just put the head back together...the solenoid screen was clean ...i really think its an oil pressure issue..i need an oil pressure gauge
Old Jun 12, 2005 | 01:42 PM
Chiovnidca's Avatar
Default Re: (Suck my DX)
Does the CEL come on?
Old Jun 12, 2005 | 02:09 PM
Suck my DX's Avatar
Default Re: (Chiovnidca)
i only get cel 22 when i try to go into vtec in third gear...it just stumbles and there is no power...it also does it if im on the freeway and im goin like 80 and i floor it in fifth and get to about 95-100 it turns on as well...thats why i figure it has to be an oil pressure problem....im gonna go get it dyno tuned tomorrow so hopefully it takes car of the problem....
also u know how there are four cam cap studs that also hold on the spark plug cover...well one of em snapped so it only bolts on the bottom....so i leak a little oil from that small opening...now i dont know if this might be the cause but im tryin to factor things out one at a time
smokinloc
Sep 29, 2010 12:55 PM
Pagley
Mar 10, 2010 03:40 PM
From_love
Sep 15, 2006 12:18 AM
TheIceMan
Jul 7, 2005 05:06 PM
