help with digital msd window switch
Old Jun 10, 2005 | 12:03 AM
GdmLaz's Avatar
Default help with digital msd window switch
k i bought MSD DIGITAL WINDOW SWITCH but theres something i can't figure out
RED WIRE= POSITIVE
BLACK= NEGATIVe
WHITE= NEGATIVE COIL
THEN my problem is with output wires
GRAY SAYS NORMALLY CLOSED. THIS WIRE WILL REMOVE THE GROUND SOURCE AT UR DESIRED ON RPM, AND COMPLETE THE GROUND CIRCUIT AT THE SET OFF RPM
YELLOW NORMALLY OPEN. THIS WIRE WILL PROVIDE A GROUND SOURCE AT UR DESIRED ON RPM AND REMOVE THE GROUND AT THE SET OFF RPM
and it says that yellow goes to the solenoid or gray so what do i do connect both of them 2 the same solenoid ??
oh and this is for a nitrous set up
Old Jun 10, 2005 | 05:37 AM
civicross's Avatar
Default Re: help with digital msd window switch (Slammed92hbonN20)
Yellow.
GdmLaz
13
Jun 10, 2005 06:34 AM
racingant
Jan 11, 2004 05:15 PM
zcivic91
Jan 15, 2003 12:03 AM
CivicEx95
Jul 18, 2002 03:26 AM
