noob question on valve adjustment
Old Jun 6, 2005 | 05:25 PM
bOOsTiNSoHcVtEc's Avatar
Default noob question on valve adjustment
I have a head laying in my garage and I was wondering if i could adjust the valve lash b4 i slap it on the block or does it have to be on the block in order to do it?
Old Jun 6, 2005 | 06:23 PM
Default Re: noob question on valve adjustment (bOOsTiNSoHcVtEc)
Old Jun 7, 2005 | 03:46 AM
anyone?
Old Jun 7, 2005 | 06:07 AM
JimBlake's Avatar
You should be able to do that, if you figure out how to handle a couple issues.
Lubrication while you're turning the camshafts?
Support the head without scratching the headgasket surface or obstructing the action of the valves.
Make sure you return the camshafts to #1tdc before installing onto an engine.
You're SUPPOSED to adjust valves with them at room temperature, so that part's good.
Old Jun 7, 2005 | 04:26 PM
Default Re: noob question on valve adjustment (JimBlake)
I can use oil or wd40 for the cams right? any other special instructions i should follow?
Old Jun 7, 2005 | 07:13 PM
Suck my DX's Avatar
i dont think that wd-40 is good enough i could be wrong...id use 60w motor oil...are the cams in or out of the head
Old Jun 7, 2005 | 07:19 PM
Default Re: noob question on valve adjustment (Suck my DX)
in.. could i take them out then do the valve adjustment?
Old Jun 7, 2005 | 07:28 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">in.. could i take them out then do the valve adjustment?</TD></TR></TABLE>
no dont do that...the whole point of a valve adjustment is to adjust the clearance between the camshaft and the lifters....the only reason why i was asking if the cams are in or out was because if they were out just apply assembly lube before puttin em in...
Old Jun 7, 2005 | 08:28 PM
ohh ok.. should i apply it all over the cams?
Old Jun 7, 2005 | 08:50 PM
Suck my DX's Avatar
only if the cams are out and ur putting them back in...if ur gonna disassemble and reassemble just for learning sake...yeah id put it on the cam lobes and lifters between the head and the cam cradles..pretty much anywhere that metal to metal contact occurs...good luck
Old Jun 7, 2005 | 10:02 PM
Tmack's Avatar
id do it with the head on the block. Your going to find that the cams are going to want to wander without the tension of the timing belt on them. Plus to do it properly your going to have to install the cams then take them off to install the head then reinstall the cams again. Too much work.
Old Jun 8, 2005 | 04:07 AM
Default Re: (Tmack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tmack &raquo;</TD></TR><TR><TD CLASS="quote">id do it with the head on the block. Your going to find that the cams are going to want to wander without the tension of the timing belt on them. Plus to do it properly your going to have to install the cams then take them off to install the head then reinstall the cams again. Too much work. </TD></TR></TABLE>
I cant slap on the head with the cams already installed?
Old Jun 8, 2005 | 05:44 AM
Suck my DX's Avatar
Default Re: (bOOsTiNSoHcVtEc)
how are u gona torque it down with the cams in it...u have no access to the headbolts
Old Jun 8, 2005 | 09:31 AM
maxrpm's Avatar
to save time i would do it when the head is on the block. This will be easier to adjust and make sure that the clearance is correct.
DA_JDM
Aug 24, 2007 01:17 PM
silver5spd
May 31, 2005 06:08 PM
Grandprix
Nov 7, 2003 05:25 PM
Ignitecivic
Sep 24, 2003 09:25 PM
Rob Dizzle
21
Jul 3, 2003 12:33 AM
