CCing a head
Old Jun 7, 2005 | 04:56 PM
2phast's Avatar
Default CCing a head
Has anyone got any simple techniques for CCing a head.
Thought about using plumbers putty to fill the combustion Chamber
and then pressing the volumn of putty into a test tube to measure.
Anyone got a better idea?
Old Jun 7, 2005 | 06:25 PM
DonF's Avatar
Default Re: CCing a head (2phast)
Buy a burette, or go to Moroso, Summit, Jeg's, any perf distributor of parts and equip.
Old Jun 7, 2005 | 07:09 PM
dohcter g's Avatar
Default Re: CCing a head (DonF)
Take a piece of plexy glass about 6''x6'' and make sure it is flat. drill a small hole in the center. Put Vaseline around the combustion chamber, press down. Then use a horse syringe (from tractor supply) with exactly 100cc or ml. of water or rubbing alcohol and fill the chamber through the hole until all the bubbles are out of it. This is the tricky part. If you have 60cc left in the syringe when you have filled the chamber then subtract from 100cc and you have 40cc. That is your combustion chamber displacement.
Old Jun 7, 2005 | 07:14 PM
dohcter g's Avatar
Default Re: CCing a head (dohcter g)
TIP: Level the head on a table before starting and the air should come to the center. Also watch for any water coming out of the intake and exh. ports. If any comes through it will not be accurate. If you don't have valvesprings installed you can also put Vaseline on the valves to seal them. Good Luck!!
Old Jun 8, 2005 | 05:29 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
You can also add a second air bubble escape hole near the intake or exhaust edge and tilt the head slightly so they rise to that side. It makes getting all the air out MUCH easier.
Old Jun 8, 2005 | 06:32 AM
2phast's Avatar
Default Re: CCing a head (tjbizzo)
Good stuff,
Thanks all, I'm going out to get a syringe.
Ralph
Old Jun 8, 2005 | 07:45 AM
IN VTEC's Avatar
I "borrowed" a bunch of 10x.1cc pipettes and pipette bulb from my Microbio lab and get by with those.
Old Jun 8, 2005 | 08:22 AM
dohcter g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo &raquo;</TD></TR><TR><TD CLASS="quote">You can also add a second air bubble escape hole near the intake or exhaust edge and tilt the head slightly so they rise to that side. It makes getting all the air out MUCH easier. </TD></TR></TABLE>
I agree! On the heads I CC now I have two holes. It seems like the air wants to stay on the sides. Either way works but still takes time and patients.
Old Jun 9, 2005 | 04:15 PM
2phast's Avatar
I just finished CCing the head. The plexiglass thing worked great, but I ended up with 4 holes. I tried 1 hole then 2 then 4.
I did it twice and came up with 42 ccs once and 42.2 ccs the second time.
Does this seem correct for a B16a head with a lightly ported combustion chamber?
I took some photos but I still have figured out how to post them. I guess I can't without a site to download them to. Anyone know a free site?
Thanks again all for the good info.
Ralph
Modified by 2phast at 5:27 AM 6/10/2005
Old Jun 10, 2005 | 04:13 AM
dohcter g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2phast &raquo;</TD></TR><TR><TD CLASS="quote">I just finished CCing the head. The plexiglass thing worked great, but I ended up with 4 holes. I tried 1 hole then 2 then 4.
Ralph
Modified by 2phast at 5:27 AM 6/10/2005</TD></TR></TABLE>
http://www.We-todd-did-racing.com Register here and then copy and paste the link of the pic you want here on H-T.
Old Jun 10, 2005 | 07:08 AM
2phast's Avatar
Thanks For the Link dohcter g.
Here is a photo of the Syringe and Plexi Plate.
The Vaseline kinda blurs the head work.
I had to get the Syringe from a local Pharmacy.
Man that was a trip. I walk in and ask the guy for the largest syringe
he has. He gives me one of those looks like he's not sure whether to call the police
or sell me the Syringe. I had to explain what I was doing and even then he wouldn't sell me the needle, just the syringe. You got to understand, I live in the land of NASCAR, Snake handlers and Jesus. I had a needle at home so it all worked out. A 60 CC syringe was the largest I could find but it was enough.
I started at 50CCs and subtracted.
Thanks again all for the help.
Ralph
[IMG][/IMG] http://www.we-todd-did-racing....D.jpg
Old Jun 10, 2005 | 12:09 PM
dohcter g's Avatar
Glad it all worked out. When you post a pic......put the link in between this [IMG][/IMG]
Old Jun 10, 2005 | 12:24 PM
2phast's Avatar
Got it
thanks
wasanissanFL
Sep 13, 2015 04:51 PM
92LudeSI
Sep 17, 2004 09:06 PM
ThEOutSidEr
Jan 27, 2004 11:24 PM
KooK
May 30, 2003 09:27 AM
