step by step vtec wirng?!
Old Jun 5, 2005 | 09:19 PM
northkai3's Avatar
Default step by step vtec wirng?!
anyone know how or know where i can find out how and which wires to run for my vtec i have a 95cx hatch with d15b jpec vtec motor running on cx ecu plan to put in a p08 but need help with the vtec!
Old Jun 5, 2005 | 09:39 PM
1995Ex_Sedan's Avatar
Your search for wiring vtec returned 413 results.
Old Jun 5, 2005 | 10:47 PM
Katman's Avatar
Default Re: (1995Ex_Sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">Your search for wiring vtec returned 413 results.</TD></TR></TABLE>
LOL
you can use my diagram to figure out the ecu pinouts for VTEC here:
http://technet.ff-squad.com/
(look under ecu & wiring for OBD1)...
I haven't quite finished wiring info for OBD1 vehicles, but since you own a CX you'll need to wire in a 4-wire 02 sensor if you plan to reuse your CX engine wire harness on your D15B engine. If get yourself a 92-95 EX/Si engine harness then you won't have to wire in a 4-wire 02 sensor, but you will still have to wire in VTEC from the ecu plugs out to the passenger side shock tower (as shown in one of my diagrams). Other than that, you should be set...
jdmh22:)
11
Feb 18, 2012 08:05 PM
sameerb1
Feb 22, 2011 08:33 PM
madvtakkk
Jan 7, 2008 09:22 AM
