84mm more with acl?
Old Jun 6, 2005 | 09:09 PM
lilmike's Avatar
Default 84mm more with acl?
i was wondering if i have a 84mm bore, eagle rods, cp pistons do i use regular size bearings or oversized?
and where can i get them cheap at?
Modified by lilmike at 5:15 AM 6/8/2005
Old Jun 7, 2005 | 06:51 AM
civicross's Avatar
Default Re: 84mm more with acl? (lilmike)
The bore of the engine doesn't determine the size of the bearings. The rod and main journals of the crankshaft do. Unless your crank has been turned, a standard size bearing will *most likely* work in your application. I sell the standard and race series ACL bearings if you are looking for them as well.
Old Jun 7, 2005 | 03:46 PM
lilmike's Avatar
Default Re: 84mm more with acl? (civicross)
?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross &raquo;</TD></TR><TR><TD CLASS="quote">The bore of the engine doesn't determine the size of the bearings. The rod and main journals of the crankshaft do. Unless your crank has been turned, a standard size bearing will *most likely* work in your application. I sell the standard and race series ACL bearings if you are looking for them as well.</TD></TR></TABLE>
how much do you sell them for? i heard camp1320.com is selling for 100 but i dono if that is shipped
Old Jun 7, 2005 | 03:48 PM
civicross's Avatar
Are you looking for the standard or race series?
Old Jun 7, 2005 | 06:29 PM
DonF's Avatar
The ones for an 84mm bore. And I am sure you can do them the chestest.
Old Jun 7, 2005 | 06:44 PM
maxxborist's Avatar
Default Re: 84mm more with acl? (DonF)
its the crankshaft that matters not the bore when it comes down to bearings.
like wat civicross said
Old Jun 8, 2005 | 04:14 AM
lilmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross &raquo;</TD></TR><TR><TD CLASS="quote">Are you looking for the standard or race series?</TD></TR></TABLE>
what is the differnce? its going to be a daily driven car and hopefully put down 360 hp.
if you can email me price. thanks
xxsupadupamikexx@aol.com
1320london
Engine Machining & Assembly
May 25, 2017 10:04 PM
Charlie Moua
Jan 16, 2012 07:01 PM
crawlin
May 24, 2007 07:30 AM
Thepanda
May 17, 2007 06:22 AM
H22Luda720
Apr 5, 2006 05:27 PM
