New Alternative to GM Synchromesh available.
Old Jun 13, 2005 | 01:12 PM
Buzzbomb's Avatar
Default New Alternative to GM Synchromesh available.
If any of the numerous Synchromesh users out there care, there is a new alternative to the expensive GM branded MTF.
AMSOIL is coming out with a Manual Transmission Fluid as a replacement for the GM Synchromesh MTF. I was surprised by the price as it looks like it's going to be just under $7.00 per quart. I believe the GM/Pennzoil stuff is petroleum, where this is synthetic.
I'm about due for tranny fluid change in the Si and I think I'm going to try this stuff out.
Thought you guys might be interested.
Modified by Buzzbomb at 6:55 AM 6/14/2005
Old Jun 13, 2005 | 02:44 PM
civicross's Avatar
Default Re: New Alternative to GM Synchromesh available. (Buzzbomb)
What are the benefits of this over the Redline MTL?
Old Jun 13, 2005 | 03:48 PM
Buzzbomb's Avatar
Default Re: New Alternative to GM Synchromesh available. (civicross)
The only real difference that I can see is that Redline does not state that their product is a direct replacement for specific OEM product numbers. They just state that it can be used in most manual transmissions. AMSOIL directly states that it replaces GM part #1234349, 12345577, etc etc.
Old Jun 14, 2005 | 04:37 AM
Buzzbomb's Avatar
bump
Old Jun 15, 2005 | 02:36 AM
Buzzbomb's Avatar
Old Jun 15, 2005 | 07:25 AM
hondaguyef's Avatar
PM sent to you BuzzBomb
Old Jun 15, 2005 | 05:31 PM
mmuller's Avatar
Mad Scientist
its still not like the friction modified synchromesh.
Still looks like a great alternative
Old Jun 16, 2005 | 12:45 PM
Boofster's Avatar
Default Re: New Alternative to GM Synchromesh available. (mmuller)
Is this better than KAAZ for LSD equipped cars?
Old Jun 16, 2005 | 03:56 PM
Buzzbomb's Avatar
Default Re: New Alternative to GM Synchromesh available. (Boofster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">Is this better than KAAZ for LSD equipped cars?</TD></TR></TABLE>
Good question, it doesn't say wether or not it's compatible with LSD. I know their 75w90 gear lube is, I run that in the WRX. Something to look into.
Old Jun 16, 2005 | 06:57 PM
LSVTEC 91 Civic's Avatar
Banned
Hell yeah! Amsoil &gt; *
Old Jun 20, 2005 | 09:52 AM
Boofster's Avatar
Default Re: (LSVTEC 91 Civic)
Yeah I've been using the $50 per bucket KAAZ (GL5 80W-90) since I put in my ITR LSD and tranny has felt pristine ever since. hybridgarage says use it
Old Jun 24, 2005 | 04:24 PM
vtecmissle's Avatar
Default Re: (Boofster)
interesting because the kaaz requires a different formulation because it is a clutch type lsd than a itr lsd which is basically a torsen and requires nothing special. Kaaz fluid is designed to control the expansion of the fluid within to allow the plates to lock under tension. No benefits at all except extra additives which may take away from lubication qualities in a itr lsd equipped transmission.
Old Jun 26, 2005 | 06:29 AM
hondaguyef's Avatar
Default Re: (vtecmissle)
I e-mailed you my info, waiting for reply.
Phil
Old Jun 26, 2005 | 04:43 PM
vtecmissle's Avatar
Default Re: (hondaguyef)
who did you email? Your title bar says Re: vtecmissle
Old Jun 27, 2005 | 04:50 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle &raquo;</TD></TR><TR><TD CLASS="quote">who did you email? Your title bar says Re: vtecmissle</TD></TR></TABLE>
He meant me. hondaguyef, I replied to your email.
Old Jun 27, 2005 | 07:39 AM
MadtownSi's Avatar
Amsoil products are top notch, I should know I sell the stuff
I have been using Amsoil oil in all my cars for years now. But I have not used the new Amsoil Synchromesh MTF. For years now I have used BG Syncro Shift II, even now with my LSD installed I still used it. The stuff is amazing!! If your using Reline, try BG, you will notice a SIGNIFICANT difference. Redline MTF = JUNK if you ask me.
My suggestion, Amsoil or BG, nothing else unless you are running a clutch type LSD
Old Aug 6, 2005 | 09:43 PM
Civic4less's Avatar
Default Re: New Alternative to GM Synchromesh available. (MadtownSi)
Awesome. I'll be needing some of this when my 5-spd comes in. I'll send ya a message soon I hope.
Old Aug 7, 2005 | 06:33 AM
DaiJekBok's Avatar
That Chrysler Synchromesh Fluid sure is expensive.
Old Aug 13, 2005 | 06:02 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: New Alternative to GM Synchromesh available. (DaiJekBok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok &raquo;</TD></TR><TR><TD CLASS="quote">That Chrysler Synchromesh Fluid sure is expensive.</TD></TR></TABLE> LOL I'm glad I'm not the only person who noticed that...
Anyways GM changed the name for their syncromesh friction modified and I didn't fee like risking it not being the same fomula so while browsing the corvette forums I found that those guys are switching to BMW's M5 MTF, it's synthetic, its cheaper then GM syncromesh Friction modified and according to them works even better then the GM stuff... Just a heads up
Twentys95hb
Transmission & Drivetrain
Jun 25, 2009 09:34 AM
avargas28
Aug 13, 2008 12:33 PM
sdr85
Jan 28, 2008 07:57 PM
sdr85
Sep 24, 2007 12:39 AM
B2FiNiTY
Oct 27, 2003 03:27 PM
