Motor Break In Write Up
Old Jun 6, 2005 | 08:25 PM
Dunc's Avatar
BCICAN
Default Motor Break In Write Up
True? False? It's your decision....thanks Felix
http://www.mototuneusa.com/break_in_secrets.htm
Old Jun 7, 2005 | 10:16 AM
tgreaves's Avatar
Default Re: Motor Break In Write Up (Dunc)
Ill let you know.. I have about 40 miles on my motor and its being broke in this way so we shall see.. I always did the easy break-in before but im trying a much harder breakin this time around..
Old Jun 7, 2005 | 10:43 AM
Mohsin's Avatar
Default Re: Motor Break In Write Up (tgreaves)
Have you had any problems in the way you used to break the engine in?
Old Jun 7, 2005 | 11:12 AM
tgreaves's Avatar
Default Re: Motor Break In Write Up (Mohsin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin &raquo;</TD></TR><TR><TD CLASS="quote">Have you had any problems in the way you used to break the engine in?
Nope, none at all.. This is just an engine that I am using to get my b-series setup all dialed in with my turbo setup so its not that important to me.. I figured I might as well try a new breakin method on it..
Old Jun 7, 2005 | 06:16 PM
hatch34's Avatar
i say break it in like your goin to drive it
Old Jun 7, 2005 | 07:41 PM
drdisco69's Avatar
I am a believer in his technique, I broke in my R motor that way. I have had no problems after around 5000 miles. It uses very little oil, especially considering how it's driven. To seat the rings, you MUST create cylinder pressure. Cylinder pressure = WOT.
Old Jun 7, 2005 | 09:29 PM
avsfan733's Avatar
me and my old kart engine builder had a ragin arguement abotu this that ended up with two engines as identical as we could get them on a dyno. It actually works from me looking at physical data (about .5hp out of only 15)
Old Jun 8, 2005 | 04:22 AM
Kidnkorner's Avatar
Default Re: (avsfan733)
I have read that before, and i beleive it! But......................I prefer the method listed in the following link even better.
Click Here y0!
PhatBoy5015
Jul 13, 2006 02:48 PM
TRAG
Mar 9, 2006 12:02 PM
hybridEj6
14
Mar 18, 2004 07:44 PM
b16crx1
Feb 20, 2004 05:49 AM
