89 CRX B16 Problems (Dizzy)
Old Jun 8, 2005 | 08:29 PM
Blanket Jackson's Avatar
Default 89 CRX B16 Problems (Dizzy)
K, I have an 89 CRX, just did a full multi port swap, including dash and engine harness. Tried to crank the car over, it cranked, but no spark to the wires. I have a brand new dizzy, and wires. I took the cap off, I am getting power to the Coil, but nothing to the spark plug. What all problems are occuring?? Should I check my main relay or would that have anything to do? There are no ECU codes being throw, since I have not had the car running (or does it matter). OBD0 B16 FYI.
Thanks for anyhelp.
Shaughn
Old Jun 8, 2005 | 11:15 PM
onepoint6i's Avatar
Default Re: 89 CRX B16 Problems (SlowSpyder)
your getting power to the coil.. so it's either your coil or your ignitor..90% of the time its gonna be the coil..get a good known coil and swap em, unless you have a test light and know which wire to probe to see if the ignitor is sending the signal....Just get a known working coil and go from there..
Old Jun 9, 2005 | 05:36 AM
Well, we used the test light, cranked the car over and there was no change in the light, unless there isn't supposed to be. We are going to try a different dizzy today and go from there.
Anyone else??
Shaughn
Old Jun 10, 2005 | 08:00 AM
Anyone??
Old Jun 10, 2005 | 09:35 AM
Redline130's Avatar
Default Re: (SlowSpyder)
Are all of your grounds good?
Old Jun 10, 2005 | 11:20 AM
tgreaves's Avatar
Default Re: (Redline130)
Reverse the 2 white wires at the dizzy..
Old Jun 10, 2005 | 11:57 AM
onepoint6i's Avatar
Default Re: (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Reverse the 2 white wires at the dizzy.. </TD></TR></TABLE>
lol...thats a good one
BUT he swaped over MPFI harness's he didnt do dual point to MPFI conversion.......unless the harness has been cut and spliced at the distributor plugs for some reason?
Old Jun 10, 2005 | 11:59 AM
tgreaves's Avatar
Default Re: (1.6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i &raquo;</TD></TR><TR><TD CLASS="quote">
BUT he swaped over MPFI harness's he didnt do dual point to MPFI conversion.......unless the harness has been cut and spliced at the distributor plugs for some reason?</TD></TR></TABLE>
Oh, didnt see that in his post.. Whenever you see the phrases DPFI-MPFI and no spark its a natural reaction to say "swap the white wires"..
Old Jun 10, 2005 | 12:02 PM
onepoint6i's Avatar
i hear you!, **** happened to me once,even after i had done several Dual-MPFI conversions....i was stumped for a while on that one!!
Old Jun 10, 2005 | 12:06 PM
tgreaves's Avatar
Default Re: (1.6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i &raquo;</TD></TR><TR><TD CLASS="quote">i hear you!, **** happened to me once,even after i had done several Dual-MPFI conversions....i was stumped for a while on that one!!</TD></TR></TABLE>
I still do it.. The wires are so close in size that its hard to tell..
Old Jun 10, 2005 | 02:53 PM
Yeah, well, still nothing yet. We are gonna try a dist. from a different CRX with a B16, and check the wiring on it. We did the other car 8 months ago, and no problems. I guess once we check this other CRX, we should find the problem on the original CRX.
Jory
Apr 4, 2011 02:44 PM
themex77
11
May 9, 2007 04:54 PM
jdmwizz87
Feb 6, 2005 01:08 PM
RussHondaCRXVtec
Dec 15, 2003 07:02 PM
wanttorace
Oct 5, 2002 10:31 AM
