piston help!
Old Jun 11, 2005 | 06:14 PM
b18c5 EG's Avatar
Default piston help!
i blew my b16....just wondering who has taken their block to get bored/honed and pistons installed...i think i blew my # 4 cylinder piston..so im going to take it apart tomorrow and bring it to a shop to have some ctr .20 over pistons installed....how much did it cost you guys for labor and the work....again im pulling it out of my car and putting it back in myself....
p.s i know every shop is different im asking how much you were charged
Old Jun 11, 2005 | 10:31 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: piston help! (94_Del Sol)
15 a hile to bore and hone, 80 to press on ctr's and shave the rods
Old Jun 11, 2005 | 11:55 PM
b18c5 EG's Avatar
thats not to bad of a price...anybody else have to do this?>
Old Jun 12, 2005 | 01:06 AM
NITROUSHONDA's Avatar
$125 to have mine cleaned and bored
Old Jun 12, 2005 | 12:16 PM
b18c5 EG's Avatar
Default Re: (NITROUSHONDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NITROUSHONDA &raquo;</TD></TR><TR><TD CLASS="quote">$125 to have mine cleaned and bored</TD></TR></TABLE>
im praying its that cheap....i need to start saving....i just spent $400 to find out my timing was off which is why the car wouldnt idle.....the same day it blew up wtf..
Old Jun 12, 2005 | 02:31 PM
slomofo's Avatar
GDD Member
$125 for bore/clean (Looks like new), assembled myself. Head was damaged when piston exploded, have your head checked.
Old Jun 12, 2005 | 03:50 PM
b18c5 EG's Avatar
i did a compression test today....wasnt good... #1 0 #2 75 #3 25 # 4 75
i have never done anything like this before somebody give me a run down on what i need to have a reliable motor with ctr pistons in it...or what other pistons are good.... can i use stock b16 rods?etc......i dont want to go to crazy but i need it to last
Modified by 94_Del Sol at 1:10 AM 6/13/2005
Modified by 94_Del Sol at 1:47 AM 6/13/2005
Old Jun 13, 2005 | 02:50 PM
slomofo's Avatar
GDD Member
Low compression on all four, it's probably your head that's screwed, not your block. Check your timing belt, fix it if it's off, then do another compression check. I'm pretty sure your only problem is bent valves on cylinders 1 and 3.
Old Jun 13, 2005 | 08:15 PM
b18c5 EG's Avatar
yeah im kind of hopeing its my pistons though so i can just rebuild it ......i heard a big POP!!! my timing belt is still tight...the spark plug is bend in one cylinder....when i have time ill take it apart and show u some pics
Old Jun 14, 2005 | 04:42 PM
b18c5 EG's Avatar
has anybody put p30 pistons in a del sol??i want my compression to be around 10.8-11....
Old Jun 14, 2005 | 04:59 PM
slomofo's Avatar
GDD Member
Default Re: (94_Del Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_Del Sol &raquo;</TD></TR><TR><TD CLASS="quote">has anybody put p30 pistons in a del sol??i want my compression to be around 10.8-11....</TD></TR></TABLE>
Honda put P30 pistons in there and i'm sure many others have done it too. Seriously though, P30's are the stock B16A3 pistons.
Old Jun 14, 2005 | 05:44 PM
b18c5 EG's Avatar
i know but jdm will bump it like .2 right? i dunno maybe ctr would be better then
Modified by 94_Del Sol at 3:31 AM 6/15/2005
CivicVX94
Feb 6, 2006 11:35 PM
vtecdamian
Jan 17, 2004 07:17 AM
crx1856
Nov 3, 2003 05:10 AM
roydogg
Aug 6, 2003 06:49 AM
InsertCleverSN
Apr 27, 2003 06:41 PM
