which cams should i use
well the set up i have is a b18c block w/ ctr pistons stock head itr manifold, vibrent 4-1 header, rc 270cc injectors, 65mm tb, iceman intake, hondata s300, adjustable camgears
Well the question i have is that i have built this engine setup before just useing itr cams and had no problems making at least 205 whp on a dyno jet, well this engine i just built made the 207 on dyno packs which are known to be 10-20hp higher than a dyno jet. Im useing buddy club spec 4 cams that i had lying around the shop, are these cams even worth useing? what cams do you think would be good on this setup?
COOL THANKS, YA JUST A LOT OF PEOPLE HAVE BEEN SAYING I NEED SOME HEAD PORTING TO USE A CAM THAT SIZE, I ALSO HAVE A SET OF WICKED STAGE 3 I MAY TRY OUT. HAS ANY ONE USED THESE ON THIS SET UP?
komat
29
Jun 30, 2009 06:47 AM
