JDM integra Cluster problems.....
Old Jan 2, 2006 | 07:49 AM
fabworxs's Avatar
Default JDM integra Cluster problems.....
OK........I just recieved my 2nd cluster and am' having the same problem.
As soon as I install the JDM cluster into my 96 integra the gas/fuel gauge goes to full and as soon as I put the USDM one back in everything is cool??????
I have gotten 2 clusters now and I need to know if anyone esle has ran into this problem. ANY HELP PLEASE~!!!
THANKS IN ADVANCE!!!!
Old Jan 2, 2006 | 12:00 PM
fabworxs's Avatar
Default Re: JDM integra Cluster problems..... (fabworxs)
ttt!
Old Jan 2, 2006 | 02:17 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
WTF? Thats an odd one man....
Old Jan 7, 2006 | 06:22 PM
I3lakeintegra's Avatar
the same thing happened to me when i put in a new cluster. what it is, is that the pins are not in the right slots. you need to find out the pin reading for the JDM cluster, and then on your harness change the pin to the right slot. this is what i did and evreything worked. hope this helps
Old Jan 11, 2006 | 11:30 AM
fabworxs's Avatar
Default Re: JDM integra Cluster problems..... (I3lakeintegra)
Did anyone ever find the link to help me on this???
I tried changing out the green film on the back but that did not work. PLEASE HELP I WANT THIS CLUSTER SO BAD!!!
thanks!!
Old Jan 16, 2006 | 01:17 AM
egcivic611's Avatar
i3lakeintegra is right, you have to change out the pins, they are in different slots. when he put his new cluster in the gas gauge went to full and when he would plug in his seatbelt the gas went to empty--since the pins are in different slots they read different things, find out the correct pin slots and switch them...its really not that hard once you find the right pin diagram.
Old Jan 16, 2006 | 04:58 AM
fabworxs's Avatar
Default Re: JDM integra Cluster problems..... (egcivic611)
Does anyone have the diagram???
PLEASE~~~~~~~~~~~
Old Jan 19, 2006 | 08:47 AM
fabworxs's Avatar
I'm still looking for the diagramon this or for someone to confirm that the fuel & seatbelt pinouts need to be changed.
HELP PLEASE!!!!
Old Jan 24, 2006 | 09:46 PM
dclsvtec's Avatar
well there are 2 kinds of jdm clusters.... the kind <U>with</U> and <U>with</U>out ABS, just get the one with the ABS. thats the one that i got the second time around trying to get the cluster working. then get the circuit board of the US cluster and put it on the JDM cluster and that should solve it... good luck and if that doest work sorry man...
Old Jan 25, 2006 | 04:16 AM
ekek888's Avatar
maybe this can help
https://honda-tech.com/zerothread?id=285567
Old Jan 25, 2006 | 04:17 PM
fabworxs's Avatar
Default Re: JDM integra Cluster problems..... (ekek888)
this one does have ASB and I'm still having issuse! I was wondering if this happens if you get the SPOON dash. If so booooooo...
Old Jan 30, 2006 | 12:17 PM
fabworxs's Avatar
Just in case anyone was wondering YES I got my cluster to work!!
Hit me up if you need some info on getting these to work inside your teg!!
redline32
Oct 6, 2007 05:00 PM
fabworxs
Jan 2, 2006 02:07 PM
knoxville
Jun 8, 2005 07:25 AM
shoei
Sep 24, 2004 05:11 AM
shoei
Sep 23, 2004 08:17 PM
