b18c1 oil cooler
Old Jan 1, 2006 | 10:13 AM
Ruben19's Avatar
Default b18c1 oil cooler
i building a b18c1 block and i will be using a b16a2 head
the car is a 00 civic si. the b16a2 block dont come with oil cooler.
so im using parts form the b16 and intall it into the gsr block.
it seem that the thermostat housing and tube arent the same because the b16 dont use oil cooler.
so im thinking using a T from the hose that goes to the head and also use it for the oil cooler.
i also have the gsr thermostat housing and tube but the tube has a extra hole on it.
i dont know if i should put a plug.
Old Jan 1, 2006 | 12:48 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: b18c1 oil cooler (Ruben19)
You need the correct water pipe. Look up the parts from a 1995 GSR here:
http://www.acuraparts247.com
http://www.acuraparts247.com/p...ch=no
EG6 Love
Jan 19, 2010 07:39 PM
2fastek
Nov 19, 2008 03:36 PM
xsi-t
Nov 12, 2005 07:45 PM
Lee_Delso
Apr 25, 2005 09:15 AM
