Y1 Tranny Rebuild
Old Dec 29, 2005 | 02:21 PM
KNoGooD's Avatar
Default Y1 Tranny Rebuild
Well< I just blew my diff. so i was wondering if i can get some advice. I was wondering what kind of lsd differential i should get and where i can get it for a good deal? also my second and third gear kind of grinds at high rpm. So i was wondering what i would have to do? Jay told me that id need to change the sychros. If so what kind can i use? from any b16 transmissions? Please help me, I dont want to buy a different transmission and ending up being messed up too. Please dont flame
Old Dec 29, 2005 | 10:00 PM
ef2_civic's Avatar
Default Re: Y1 Tranny Rebuild (KNoGooD)
if u ever looking for a replacement instead of a LSD upgrade let me know
I got a S1 diff lying in a box somewhere
Old Dec 30, 2005 | 12:23 AM
EnzoSpeed's Avatar
Default Re: Y1 Tranny Rebuild (ef2_civic)
There's actually a dozen or so problems that can cause gear grinding. People just automatically assume it's the synchros. You won't know for sure until you take the housing off the tranny and have a look inside.
Old Dec 30, 2005 | 12:50 PM
KNoGooD's Avatar
Default Re: Y1 Tranny Rebuild (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">There's actually a dozen or so problems that can cause gear grinding. People just automatically assume it's the synchros. You won't know for sure until you take the housing off the tranny and have a look inside.</TD></TR></TABLE>
IC, thnx ill take it to the shop, so they can take it apart, but does anyone know what kind of lsd diff i should get? any suggestions?
Old Dec 30, 2005 | 03:24 PM
rainforest's Avatar
the grinds are probablly the syncros check for wear on the syncros and sleaves. i personally dont have one but i have drove in 2 cars with them and want one bad. quaife lsd's they are awsome and sexpensive.
Old Dec 30, 2005 | 05:39 PM
EnzoSpeed's Avatar
Default Re: Y1 Tranny Rebuild (rainforest)
Grinding is only caused by worn out synchros about half of the time. The other half of the time it's caused by misalignment issues.
But the misalignment issues can be caused by lots of things. Improper clutch install, broken c-clips, or basically anything broken inside that causes the mainshaft to fall out of alignment.
hfrex
May 14, 2009 03:20 PM
stixGSR
Jul 9, 2005 01:27 AM
JDM SLICK
Jun 3, 2005 09:26 AM
endlessdv
May 29, 2004 05:58 PM
black2001ITR
Sep 30, 2003 07:27 AM
