idle problem rolling my eyes
Old Dec 29, 2005 | 08:54 PM
bleedblue94's Avatar
Default idle problem rolling my eyes
ok i have a b16 block with a gsr head and itr tranny running off a jdm p30. butterflies have been removed from the manifold. motor ran fine when i put it in...after awhile it developed this bogging idle when it warms up. it comes and goes. car idles fine till it warms up then sometimes as its idling at 700 rpm it putts and boggs alittle to 600 or 650 but its not the speed thats concerning me ... its the putt noise it make just was it boggs. ive also noticed there seems to be a very slight sputter in the idle when its not doing this. ive tried a couple good dizzys and a different ecu but i still have the same problem....please any help
Old Dec 30, 2005 | 07:41 AM
Default Re: idle problem rolling my eyes (bleedblue94)
anyone have any ideas?
Old Dec 30, 2005 | 10:35 AM
mattssi's Avatar
valve lash maybe?
Old Dec 31, 2005 | 10:51 AM
Default Re: (mattssi)
i just set that and i checked it again and its all in spec
Old Dec 31, 2005 | 11:05 AM
ej1_lsvtec's Avatar
check all vacuum houses , if not check the throttle body gasket.
Old Dec 31, 2005 | 11:09 AM
Default Re: idle problem rolling my eyes (ej1_lsvtec)
there are no vaccum leaks and i have replaced the tb gasket before....i know for a fact those things are all good
Old Dec 31, 2005 | 04:06 PM
bump
Old Jan 1, 2006 | 02:57 PM
come on tech guys
Old Jan 1, 2006 | 04:10 PM
Dogginator's Avatar
Daisy... Daisy...
Have you cleaned the IACV? Have you set the idle bleed screw on the TB?
Old Jan 1, 2006 | 10:21 PM
Default Re: idle problem rolling my eyes (Dogginator)
yes and yes....there was nothing on the screen it was clean and as far as the idle screw goes when i set it...everything ran fine, then the whole problem started again
Old Jan 4, 2006 | 10:05 AM
ttt
nikkon
Aug 3, 2011 06:21 PM
h-o-n-d-a
Aug 3, 2009 05:15 PM
95dc2teg
Sep 11, 2007 05:49 PM
Midori Green
Jan 3, 2007 03:13 PM
QWKPHKR
Aug 11, 2002 11:35 AM
