ITR vs. CTR JDM piston question
Old Dec 29, 2005 | 05:30 PM
ntensehonda's Avatar
Default ITR vs. CTR JDM piston question
I know it's prolly been discussed, but I ran a quick search and didn't find anything.
So, question is this.
LS/VTEC motor (B18B block, JDM B16A SiRII Head)
Which Piston will give higher compression? The JDM ITR, or the CTR piston.
I was under the impression that the ITR was a higher compression, however, I just looked at some side by side pics, and the CTR appears to have a much higher dome.
Help?
Old Dec 29, 2005 | 05:37 PM
Default Re: ITR vs. CTR JDM piston question (ntensehonda)
Old Dec 30, 2005 | 12:27 AM
Takumi Fujiwara's Avatar
The CTR pistons will give the higher compression.
Old Dec 30, 2005 | 01:11 AM
IN VTEC's Avatar
Dome size isn't the only thing that matters. You also have to consider the piston's compression height and the volume of the valve reliefs. With that said, the CTR pistons produce the smaller combustion chamber volume.
shomershavis
11
Sep 4, 2004 10:19 AM
CircuitFG
Jul 5, 2003 09:01 AM
duRritztiNy
35
May 16, 2003 10:36 PM
10seconds
Jul 3, 2002 12:22 AM
X2BOARD
Aug 9, 2001 11:00 PM
