Help! Running SO RICH
Old Jan 2, 2006 | 05:51 AM
danerr's Avatar
Default Help! Running SO RICH
My engine runs <U>EXTREMELY</U> rich. Its so rich ive had to lean it out with a vafc to get it to start up.
<U>the vafc was installed correctly as a quick fix to get it running</U>
this car is completely stock, nothin changed
Ive had to give it the following fuel settings:
-50 (MAX). it wont start up any other way..
what I know:
map sensor good.. vafc sees correct volt/psi from this signal
throttle sensor good
fuel pressure perfect
injector spray patterns are perfect
reset ecu, no fix
no codes present.
what kind of malfunction could cause the mixture to be SO RICH??
please help
2001 prelude h22a4 40,000km
Modified by danerr at 5:59 PM 1/4/2006
Old Jan 2, 2006 | 10:09 AM
GripDrift's Avatar
Default Re: Help! Running SO RICH (danerr)
2006.1.2
EXTREMELY rich running? Any black smoke coming out the exhaust?
How was your VAFC wired? (Correctly?)
You could check the timing and it's related parts... maybe even the distributor and spark for the engine. It sounds like you have plenty of fuel and that the fuel system is OK, but if you get poor spark then your motor won't burn the fuel being mixed (causes rich running...).
Good luck!
Old Jan 2, 2006 | 10:10 AM
B6tPoweredMx3's Avatar
First off what injectors? and what have you done to the motor?
Checked for a nasty vaccum leak?
Old Jan 2, 2006 | 02:23 PM
new2novas's Avatar
Default Re: Help! Running SO RICH (B6tPoweredMx3)
could be coolant temp or 02 sensor....defintely check for any vacuum leak, i like to use some carb cleaner and spray it around gaskets and any vacuum hose
Old Jan 4, 2006 | 05:10 PM
danerr's Avatar
Default Re: Help! Running SO RICH (new2novas)
no there is no black smoke. the mixture is correct because ive had to compensate via the vafc. i shouldnt have to do this though
Could any other sensor make it this bloody rich all the time, all rpm? (besides the ones ive checked).
no vaccum leaks, no exhaust or intake clogs.
my fuel correction is at -50%. it still idles and pulls hard though. if i slowly bring the fuel down to 0% correction, it bogs and stalls because its too rich. this is just to give u an idea of what is going on.
thanks for the idea guys anyone know what this most likely is?
Modified by danerr at 4:14 AM 1/5/2006
Old Jan 5, 2006 | 04:30 AM
danerr's Avatar
bump for help
01ITR#173DC2ning
Mar 3, 2006 06:15 PM
silverintegra83
Aug 6, 2004 11:38 AM
Firewerks
Jul 4, 2004 07:02 AM
gigantor
Nov 11, 2003 07:59 PM
BDTURBO
Feb 27, 2003 10:56 AM
