WHat does a 3rd grind swap usually entail?
Old Jan 8, 2006 | 03:43 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default WHat does a 3rd grind swap usually entail?
I got a ls tranny with a 3rd gear grind.
What is the problem?
Old Jan 8, 2006 | 07:56 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: WHat does a 3rd grind swap usually entail? (MugenHonda)
Have you changed your transmission fluid lately?
Old Jan 8, 2006 | 10:05 AM
cambam20's Avatar
your syncro in that gear is going out !!! sorry buy the woving kevlar kit its 350.oo then you can beat on it !!
Old Jan 8, 2006 | 11:26 AM
IN VTEC's Avatar
It could involve replacing the 3rd-4th gear synchro set and 3rd gear. The parts are probably around $250 for OEM honda parts.
Old Jan 10, 2006 | 06:41 AM
MugenHonda's Avatar
Default Re: WHat does a 3rd grind swap usually entail? (IN VTEC)
thanks no its has nothing to do with changing tranny parts.
Something is wrong and I want to change the parts, just want to figure out what can be wrong
gearspeed here i come
Old Jan 10, 2006 | 08:48 AM
Dogginator's Avatar
Daisy... Daisy...
Change the transmission fluid to see if that resolves the problem. It is cheap and easy. Sure, your third gear synchros have some damage, but you may be able to extract more life from them with a fluid change.
ClemsonME
16
Aug 18, 2009 10:09 PM
Rpizzle
Apr 11, 2005 03:24 PM
allmotorb17a
Feb 2, 2004 07:09 PM
elevatethis
41
Nov 24, 2003 12:02 AM
RTW DC2R
Sep 14, 2003 06:02 AM
