bent valve??????
Old Jan 4, 2006 | 05:31 PM
fitboy's Avatar
Default bent valve??????
What are the symtoms of a bent valve?????? My ls all motor just started to sputter during accel... yesterday and now it sputters all the time....
Old Jan 4, 2006 | 05:32 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: bent valve?????? (fitboy)
Usually slightly bent valves misfire at low RPM. Did you overrev the engine?
Old Jan 4, 2006 | 05:38 PM
fitboy's Avatar
Default Re: bent valve?????? (Dogginator)
no, I have not ran it hard latley but it rained yesterday I think maby water got into my CAI... It seams like I am running on one cylinder..
Old Jan 4, 2006 | 05:40 PM
Dogginator's Avatar
Daisy... Daisy...
What car do you have? Are there any CELs?
Old Jan 4, 2006 | 05:43 PM
fitboy's Avatar
It is an integra ls all motor... 10.5 com, crower stageII cams and 1 over valves.. I thought it may be a vaccume leake at first but it got extremly worse when i went to work...
Old Jan 4, 2006 | 05:48 PM
fitboy's Avatar
what are CELs????
Dogginator's Avatar
Daisy... Daisy...
I would suggest running a compression test. I assume that you have an OBDI ECU?
Old Jan 4, 2006 | 05:49 PM
fitboy's Avatar
never mind.... NO thats whats wierd there are no check engine lights on.... any other suggestions??
Old Jan 4, 2006 | 05:50 PM
fitboy's Avatar
yes its OBD1
Old Jan 4, 2006 | 05:52 PM
Dogginator's Avatar
Daisy... Daisy...
OBDII would have told you which cylinders were misfiring. The compression test is a good, cheap first step.
Old Jan 4, 2006 | 05:53 PM
fitboy's Avatar
Thanks a lot!!! I appreciate it!!!!!
I Am White
Apr 18, 2007 10:05 PM
B20inDCinLBC
Oct 21, 2006 09:40 PM
RGoose18
May 21, 2004 10:13 AM
BamaGSR
Mar 29, 2004 07:16 PM
JdmIntegra98
Jul 3, 2003 03:58 PM
