Fuel Pressure Issue
Old Jan 4, 2006 | 09:34 PM
Vtec-Mike's Avatar
Default Fuel Pressure Issue
Hey guys,
I am running a B20Vtec setup (Stock block, stock Head) with minor bolt on mods.
The fuel pump that I am using is the Walbro 255 in tank, with the B & M command-flo regulator.
My problem is that no matter what I do to that regulator, I can't get my fuel pressure below 50psi. I have tried turning it all the way out and the car will idle but will barely run when I drive it. But even with this issue the fuel pressure always shows 48-50psi. I have also checked the guage for accuracy.
Has anyone else run into a issue like this?? Is my regulator too "weak" for my fuel pump??
Thanks in advance for any help!
Old Jan 6, 2006 | 12:29 AM
D@nnY's Avatar
Default Re: Fuel Pressure Issue (VtecLuvr00)
thats normal ...all the regulator does is cause a restriction at the end of the fuel rail to change the pressure...those type of regulators even when completely open still cause to much of a restriction to lower the higher pressure from the 255 fuel pump
you can get a more expensive regulator or drill a small hole in the stock one to relieve pressure...
Old Jan 7, 2006 | 10:02 AM
Vtec-Mike's Avatar
Default Re: Fuel Pressure Issue (D@nnY)
awesome, thanks for the info!!
jman86
Nov 7, 2024 12:19 PM
weekendboost
Sep 1, 2018 08:51 PM
Boognish
Jul 24, 2005 08:16 PM
CivicHatchback14
10
Sep 22, 2004 09:06 PM
