OBD2 Crank angle sensor help
Old Jan 7, 2006 | 05:41 AM
HondaPartsHero's Avatar
Technical Hero
Default OBD2 Crank angle sensor help
I am trying to help a friend with his swap into his 95 civic with a B18C swap but need to see what the harness end of a Crank angle sensor plug looks like so I can connect it. What other honda/acura cars use CAS so I can get the plug end off of some other car. Anyone have a pic of the harness end so I can go looking?
Old Jan 7, 2006 | 12:07 PM
TurboLSVtecTeg's Avatar
Default Re: OBD2 Crank angle sensor help (HondaPartsHero)
The Crank Angle Sensor looks like the Back-up light switch plug on the front of the tranny. It routes over the top of the alternator, down near the timing belt and goes in behind the lower timing belt cover and bolts to the oil pump. I will have a shielded wire going to the connector.
Old Jan 7, 2006 | 08:44 PM
d16vtecx's Avatar
Default Re: OBD2 Crank angle sensor help (TurboLSVtecTeg)
the crank angle sensor is on the oil pump near the crank pulley
if his car is a 95 then he doesnt need to hook up the sensor cuz his car is obd1 and that sensor is only obd2
Old Jan 8, 2006 | 01:03 AM
ekb16's Avatar
looks like this but a male end...this is a picture of the plug that plugs onto the CAS
Old Jan 8, 2006 | 05:36 AM
Technical Hero
Default Re: (ekb16)
awesome thats just what i needed, thanks
Old Jan 8, 2006 | 08:55 PM
hatchi's Avatar
if he is using an obd1 ecu you dont need the Crank Angle Sensor.
Old Jan 9, 2006 | 08:49 AM
JimBlake's Avatar
Default Re: (HondaPartsHero)
Make sure you're talking about the same thing. It's the crank fluctuation sensor (CKF). If so, the OBD-1 ECU isn't looking for it.
Old Jan 22, 2006 | 07:36 PM
integraduo's Avatar
Default Re: (JimBlake)
you shouldn't need the CKF sensor if it's OBD1....if you have it, lMK, I've been looking for one ....either way, good luck with the swap
vic
Old Feb 1, 2006 | 08:17 PM
97CivicDad's Avatar
Default Re: (integraduo)
We just completed a swap in a '97 Civic and installed a '96 Integra B18B. We have the CKF sensor installed on the front of the oil pump, but we keep getting a P1337 engine code. I checked the Ohms and it appears that the sensor is ok, but I can't get the problem to go away. Any ideas?
Thanks,
Ron
Frisco, TX
slowestek
Feb 28, 2010 09:21 PM
d15vtecivic
Nov 21, 2007 02:38 AM
aznlaoboi315
Sep 9, 2007 02:59 PM
blowbyu24
Jan 12, 2007 10:54 PM
EKB18BPR3
Mar 13, 2005 07:22 PM
