ECU cel code 15?
Old Jan 6, 2006 | 05:19 PM
proracer718's Avatar
Default ECU cel code 15?
Im gettin this code but dont know wat it is.
#15 - Ignition Output Signal missing or defective ignition output signal
wat is that? and what do i have to change to fix it and what would cause this?
Old Jan 6, 2006 | 05:32 PM
danerr's Avatar
Default Re: ECU cel code 15? (proracer718)
dont quote me on this, but i beleive this means your igniter (inside the distributor) isnt sending the pulse (tach signal) back.
the ecu sends pulse to igniter, the igniter sparks the coil and sends the tach pulse every time it sparks the coil.
your igniter might be bad or loose connection.
does your tach still work?
please follow up
Old Jan 6, 2006 | 08:07 PM
Default Re: ECU cel code 15? (danerr)
Well when i try to start it is starts bogs and shuts off. I mean the tach needle and everythign still moves.
Old Jan 20, 2006 | 11:43 PM
Stationwagon's Avatar
bump, i have the same problem, tryin to figure it out as well
Draven8795
Feb 14, 2012 03:49 PM
flatbackcivic
Jun 10, 2005 02:17 PM
EGJDM
Feb 5, 2005 12:27 PM
*Boostwerks*
Dec 24, 2004 10:10 AM
