timing belt question
Old Dec 30, 2005 | 10:06 AM
GsrTurboCRX88's Avatar
Default timing belt question
are gsr timing belts the same size as a b16 timing belts? the reason I ask is because i have a b16 block with a gsr head and the timing belt seems too short. do i need a gsr?
Old Dec 30, 2005 | 10:24 AM
mattssi's Avatar
Default Re: timing belt question (GsrTurboCRX88)
The gsr belt should be larger due to the taller deck height of the b18 block.
Old Dec 30, 2005 | 10:35 AM
Default Re: timing belt question (mattssi)
So i should use a gsr timing belt then?
Old Dec 30, 2005 | 10:48 AM
mattssi's Avatar
not sure.. Are you sure that the b16 is too short. You have the tensioner loose and it will not fit up? Is it even close to fitting?
Old Dec 30, 2005 | 12:15 PM
Default Re: (mattssi)
it is very close to fitting, the tensioner is loose. I am afraid if i try to pry it on I will snap it
Old Jan 3, 2006 | 11:22 AM
Default Re: (GsrTurboCRX88)
I got it figured out. The b16 worked after I played with it for a while
Old Jan 3, 2006 | 11:56 AM
mattssi's Avatar
They do go on pretty tight. It would take alot to snap a timing belt, especially a new one.
03EM2guy
Aug 27, 2010 07:11 PM
fizik
May 8, 2009 01:20 PM
AZintegragsrT
Jan 11, 2006 10:21 AM
TheThiefTheKnife'NTheGun
Jan 25, 2005 09:40 PM
